Thread: Setting up a pixel matrix in configure preview
    Mar 2018
    33
    Default Setting up a pixel matrix in configure preview
    Ok, I missing something here, I'm setting up a matrix in V3 , 24x48 = 1152 pixels. I have it set up under the "Setup display" tab as described, So moving to "Configure Preview" usually I can click on the name of my prop and then click on the object such as under "Basic Drawing" and then draw out what I need. But in this case I'm trying to do the pixel grid using the "Smart Objects" , I thought I would just click on the name of my gird under the elements side and then click on the pixel matrix smart object and it would appear in the in the preview window but I get nothing.
    What am I doing wrong?
    Maryville, Illinois
    1,467
    Default Re: Setting up a pixel matrix in configure preview
    It doesn’t just appear. You have to click and drag a rectangle in the preview area after the steps you did. Sounds like you are missing that last step.
    Mar 2018
    33
    I knew it was something simple Thanks!
