Results 11 to 20 of 21
Thread: FPP - changed external storage option - now can't contact fpp
    Jan 2010
    Mims, Fl
    662
    Default Re: FPP - changed external storage option - now can't contact fpp
    Quote Originally Posted by K-State Fan View Post
    I have always done it this way and never seen it any other way.
    route -p add 192.168.101.0 mask 255.255.255.0 192.168.1.101
    I will try the -p after route and see if it stays
    West Bloomfield, MI
    639
    Quote Originally Posted by ben&bobbi View Post
    The order is important. The "-p" must be right after "route" as others have posted. You can Google the route command and see all the correct configurations and order.
    Ed
    Happily retired
    Jan 2010
    Mims, Fl
    662
    ok, need help here again.
    i entered this
    route -p add 192.168.5.0 mask 255.255.255.0 192.168.0.124
    controller is 192.168.5.145
    RPI is 192.168.0.124
    What do i have entered wrong? I can not see the controller through the RPi. I had to reload FPP and updated firmware on the E682 and trying to see it through the RPi again. I thought i had screen shots of everything, but can't find the CMD window screenshot!
    West Bloomfield, MI
    639
    i entered this
    This looks correct. If you do a route print in the command window, does it show this routing as persistent? Other possibilities are that your security software is blocking this. You may need to change the settings there to make this a trusted IP address. Also double check all the RPi settings (both eth0 and wlan0). Make sure the box is checked that says "Enable Routing between network interfaces." Post screenshots of the two RPi windows for eth0 and wlan0.
    Ed
    Happily retired
    Jan 2010
    Mims, Fl
    662
    i don't believe anything changed on the computer side. Here are my settings for lan, etho and routes. Looks like i might have added a couple wrong ones.
    West Bloomfield, MI
    639
    You have a different controller address in your screenshot than you listed in a previous post. Screen shot shows controller as 192.168.5.250, previous post shows 192.168.5.145. You also need to add manual DNS info. Also, from the screen shots, I can't tell if the "Enable Routing between network interfaces" box is checked. Finally, I would delete the incorrect routes to make sure they aren't causing any conflicts.
    Ed
    Happily retired
    Jan 2010
    Mims, Fl
    662
    192.168.5.250 is what i have for RPi
    192.168.5.145 is my controller
    I think i see the issue, my 192.168.5.145 has gateway 192.168.1.124, but it should be 192.168.0.124.
    "Enable Routing between network interfaces" box is checked, couldn't get it all in one shot.
    West Bloomfield, MI
    639
    Did you get everything working?
    Ed
    Happily retired
    Jan 2010
    Mims, Fl
    662
    not yet, haven't gone and googled how to remove the wrong ones.
    thank you for checking
    West Bloomfield, MI
    639
    route delete destination network for example, 192.168.5.0
    Ed
    Happily retired
