Results 11 to 15 of 15
Thread: some idea's
    4,065
    Default Re: some idea's
    I have one channel to a renard controller configured and active.
    Maryville, Illinois
    1,708
    I wouldn't think either of you should have the resource contention problem with multiple controllers. The fact that it clears after a restart for Popo seems to indicate some type of problem that builds over time and does not clear. I know you have a work around, but I would still like to figure out what is causing it, so any additional info you guys can feed me would be appreciative. I may need to do some more memory profiling on top of what I did before.
    4,065
    will do. i am not planning to sequence anything for a few months but I will shift my schedule a bit to see if I can trigger the issue again.
    Aug 2013
    Surprise, Az
    556
    It's a bit odd in that sometimes it occurs after loading in a busy sequence and playing it the 1st time, other times it's after I have been sequencing for awhile. So no real rhyme or reason that I can see.
    Jul 2015
    Townsville Aus
    66
    Quote Originally Posted by Popo-B-Trippin View Post
    About the same for me, It seems to be a combination of things. I always sequence without any controllers running, basically they stay off all the time because I use FPP but I also do not do Vixen any favours with channel count (alot of empty or unfilled universes
    ) I have found that when the sequence gets fairly large, when I have been mucking around with the display or set up and have not restarted the program afterwards is when it tends to happen. I have also noticed a fairly large RAM commitment when opening some sequences.
