Results 1 to 6 of 6
Thread: Pi cap
    Apr 2018
    6
    Default Pi cap
    Hello Iím wondering if you can use a pi cap to run ambilight for a tv if so what software would I need???
    Itís the lights around the tv to change with the movie.
    3,547
    Default Re: Pi cap
    Yes you could adapt the arduino code to run on a PI. You would still need to run something like the "Adalight.pde" java code on a computer that is playing the movie (Could be the PI as well I suppose).
    NOTE: Using a DIY solution means it works only for movies playing from a computer external to your TV. The software playing the movie also outputs a data stream with information similar in content to a generic serial stream from xlights or Vixen (Conceptually similar but more robust).
    3,547
    Default Re: Pi cap
    FYI: My wife would throw out the TV if I did that to it.
    North Richland Hills TX
    627
    Default Re: Pi cap
    how about a ESPIXELSTICK and MQTT. It should be pretty easy to do.
    May 2016
    235
    Default Re: Pi cap
    When I was building my theater room, I was told that the lighting around the screen would keep you from getting too tired, so there was some functionality to the decoration. See how that goes over with your wife. Mine didn’t buy it.
    Apr 2018
    6
    Default Re: Pi cap
    I tried raspi lt but my pi would not let me sign in for some reason so now I have Lightberry and donít have the money for their controller a friend wants to help me with a pi cap from falcon
