Page 1 of 6 123 ... LastLast
Results 1 to 10 of 53
Thread: Quick question about Renard
    Dec 2018
    49
    Default Quick question about Renard
    Iím new to all this. I bought a used Renard SS24 that is setup with the DMX firmware. Would I set this up as a Renard controller in Xlights or as a Renard?
    4,129
    Default Re: Quick question about Renard
    Renard is an overloaded term. The renard line of controllers can be configured to run many protocols. two of the more popular are the renard protocol and the dmx protocol. the show player only cares about which protocol you are using. you need to configure xlights to use dmx and then you need to get a usb2dmx dongle. those cost more than the usb to rs485 generic dongles that the renard protocol uses. i suggest reflashing the pic on your renard controller to use the renard protocol. your life will be simpler.
  3. Likes mrGrumpy, Wayne J liked this post
  4. #3
    Dec 2018
    49
    Thanks for the response Martin! Last year was my first year adding pixels to my display.... 4 leaping arches driven by an aphapix4. Previously I had all static led string lights. I want to do a little something with all the led string lights so I decided to add a renard to the mix. This year I plan on adding a house outline and maybe a few other props driven by a falcon.
    So if I wanted to connect the Renard straight to my laptop to familiarize myself right now, my best and easiest option would be to buy a usb2rs485 dongle and re-flash the renard, correct? I've never flashed a controller before. I know I need a programmer to do this but is it something that's complicated?
    Eventually, I would like to have the renard connected through the falcon so is that just a matter of plugging the renard into the falcon and setting up the falcon to see the renard?
  5. #4
    Houston, TX (near Katy)
    985
    The Sticky folders here are a good read. Wayne J has some very good videos for flashing pics. It is a pretty straight forward process, especially if you do not need to make changes to the firmware (.asm file) and use the hex file provided.
    That's a feature not a bug.
    There's no charge for that.
  6. #5
    Mooresville, NC
    7,590
    This is how to flash PICs...easy peasy!
    http://doityourselfchristmas.com/for...SMWIN-software
  7. #6
    4,129
    A renard controller running the renard protocol is one of the simpler things to set up and configure. look at the videoes and remember that many people have done this so there are lots of people to help.
  8. Thanks Wayne J thanked for this post
    Likes TazChaLet, Wayne J liked this post
  9. #7
    Dec 2018
    49
    Going to order a programmer and give it a shot. I know where to come if I need help.
  10. Likes Wayne J liked this post
  11. #8
    Dec 2018
    49
  12. #9
    Mooresville, NC
    7,590
    Quote Originally Posted by cjrobin27 View Post
    The one I showed you in our PMs is perfect for what you need.
  13. Likes TazChaLet liked this post
  14. #10
    Dec 2018
    49
    10-4...I'll order the one you PM'd me.
