Well, the maximum pixels per output that you “want” to run really depends on the frame rate of your sequence. If you’re running a sequence at 40FPS, then you may get some lag at the end of a long string. Otherwise, at 20FPS, you can push more than 1000 pixels without difficulty. For most sequences 20FPS is adequate, but the 20 vs 40 vs custom is a semi-religious topic upon which you will get a number of opinions.
With respect to Vixen setup, someone in the know can answer that.
