Results 1 to 7 of 7
Thread: Can Renard SS24 drive these lights
    51
    Default Can Renard SS24 drive these lights
    https://www.aliexpress.com/store/pro...7a994e4akOdACq
    Was looking to use those instead of store bought light to give the house a more modern look- don't want to jump into Pixels just yet, but figured this would give me the pixel look.
    Thoughts? Anyone used these? Would these be dimmable or just on/off?
    Winter Haven Florida
    3,039
    Default Re: Can Renard SS24 drive these lights
    these lights are dc lights renard ss24 run ac lights
    James WinterHaven Fl
    4,485
    the ss24? no. one of the other ss varients that have dc outputs? yes
    51
    Sorry should have been more clear....I would have these running with a 12v power supply (something like this- https://www.amazon.com/dp/B00FEOB4EI..._x.nwCbNQZJW20)
    That would feed 12v DC but using the Renards to control them. Would that work and would that allow dimming?
    Chesapeake, VA
    761
    You could with the wall warts but you would have a delay in timing. A 12v DC controller would serve you better.
    [SIZE=3][B]8000 + E1.31 Channels (5x E68x controllers)
    128 Renard Channels[/SIZE][/B]
    sequencing with LightShow Pro 2.8 and/or Vixen 3 (using xLights scheduler)
    2 x Pixel Mega Trees, RGB Pixel Roofline, 2 x RGB Pixel Spinners, 11 x Pixel Bushes, 6 x GECE Icicle Arches, 16 x RGB Mini Trees, 2 x Vertical Pixel Poles,
    12 x 10w RGB Floods, 160 Strobes controlled by Arduino
    [URL="http://www.controlthelights.net"]http://www.controlthelights.net[/URL]
  6. Likes TazChaLet liked this post
  7. #6
    51
    Would the delay be “even”? Meaning I can use the delay function in FPP to get everything to sync? Also are these dimmable? I couldn’t tell from the description.
  8. #7
    4,485
    You would not get any dimming. Look into a DC version of the Renard. Those strips do dimming using PWM. Varying the 12v woould not result in anything you want.
