Results 21 to 30 of 41
Thread: No Range at All.. Not Even 12 Inches...
    Hicksville, New York
    77
    Default Re: No Range at All.. Not Even 12 Inches...
    Quote Originally Posted by esmiller View Post
    Which one is that? Cannot find it listed in their information.. must be missing it !
    https://www.ebay.com/itm/DSP-PLL-87-...item3f6747d0c1
    1,273
    Just make sure you solder at least a 29.5" wire to that ANT connection. I am just using a single wire (solid) from a network cable. Mine has served me well for 3 years now. Goes for several 100' about an 1/8 of a mile clear.
    Columbus, OH
    4,161
    Also, at that price, you should buy two so you have a spare.
  4. Likes Ruppro liked this post
  5. #24
    276
    This is good advice. I used one of these for a couple of years and then the USB connector came off in the middle of December. I had to scramble for a spare. Fortunately another member was nice enough to sell me one.
  6. #25
    77
    Will do.
    Thank you all for your kind help!
  7. #26
    1,273
    Also beware of knock-offs, I ordered a couple for spares (different vendor) and when they came in they were not exactly as pictured (which my 1st one was and worked flawlessly), they would not show up as a sound device when you connected the USB, they only work when you plugin an audio cable. Ordered a couple more from my original vendor and they are the ones pictured and have no issues
    bad ones are w/o antenna, the good one has the antenna attached. You can see the different board size, component layout is different.
  8. #27
    77
    Pretty sure that is the one I got. The one with the antenna.
  9. #28
    1,273
    Yea, They all use the same picture, even the 2 "bad" ones. It was just that when they arrived they were "not as advertised". I did get a refund and the vendor did not want them back, so it all ended well.
    Sent from my ASUS_A009 using Tapatalk
  10. #29
    Chambersburg, PA
    632
    I used those for my 2017 show flawlessly. I also had bought a second as a back up. I was running FPP 1.8 at the time. This year when I went to use the same setup the sound was terrible, on both previously used and tested transmitters. The only thing that was different for me was I was now running FPP2.5x. Did anyone have sucess using these transmitters with RasPi running FPP 2.x?
    2016 - No Display
  11. #30
    306
    Yup—I used those last year as well. No problems
