Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 45
Thread: No Range at All.. Not Even 12 Inches...
    4,847
    Default Re: No Range at All.. Not Even 12 Inches...
    I hope you don't plan to use that in the US. That power level into a good ground plane antenna will get you shut down pretty quick. I also use 10mw into a ground plane antenna and get well over half a mile. My antenna is only 10cm from the ground. I suspect the signal would go much further if I raised it up.
    Hicksville, New York
    225
    Quote Originally Posted by jackfrost2 View Post
    Kinda makes you wonder IF the final IS really good to go , or is it fried ? ( seeing as to how they are USED )
    I guess I'll just order a new part.
    225
    Yea I'm kinda in the US. And the little antenna I use that's why I'm confused on why the range is so small when it's almost 5W. If I use no antenna would that cause damage?
    4,847
    no antenna == destroyed output transistors. low power transistors may last a few minutes. high power transistors last seconds. that is what the wand antenna is for. it keeps the transistors alive until you attach a real antenna. if you try to use the wand antenna then you need to make sure you set it to a correct length or you may still destroy the transistors.
    225
    Haha, when I first used used it. I had no antenna connected so that's my problem...
    Sep 2018
    119
    Yep... you toasted the output transistors .
    225
    Gotta learn somehow, ya know? Don't use things without antennas
    Delaware, OH
    4,546
    There's no telling what all blew. For 7W of output, that would be a multistage unit and there may be multiple parts blown.
    I'd return it and buy something more forgiving and more appropriate.
    In the case of a transmitter, more power does not mean better.
  9. #19
    225
    Yea I'm just forgetting about that one and I bought the one Canispater has. The $5 one that's built.
  10. #20
    Aug 2007
    TENN
    3
    Quote Originally Posted by Spankyty View Post
    Which one is that? Cannot find it listed in their information.. must be missing it !
