Results 1 to 10 of 12
Thread: Need help with Renard SS24
    Jan 2019
    Dallas, TX
    16
    Default Need help with Renard SS24
    Hi guys,
    I just bought a used RenardSS24 from one of the member here and trying to test and feel what is like.
    1- Currently, I am using Vinex 3.5 update 4 64bit version.
    2- I followed this topic to connect from PC to Controller for the tool that I have at home/work - Modification for using this adapter for common RS-485 adapters
    http://www.doityourselfchristmas.com...485_Converters
    I currently waiting for my order arrive (https://www.amazon.com/dp/B00NKAJGZM?ref=yo_pop_ma_swf) to compare and trouble shooting #2 is right or wrong or something relate to cable/network.
    3- I plugged jumper in JP2 according from wiki page (http://www.doityourselfchristmas.com...ntroller_Board) in section Configuring the jumpers on Renard SS boards
    4- Power LED green light is On. Nothing else on.
    How do I know the controller is working correctly?
    How do I know between controller and PC is communicate correctly?
    I want to test one string of light in channel 1 to see if it on or blink or on/off.
    I wanted to start early and test and feel how it works for the kids. My wife think I am crazy to play with Xmas light stuff in January.
    Any input or help is very appreciated. Thank you.
    Last edited by thangkhungdien; 01-25-2019 at 02:18 PM. Reason: change from RS232 to RS485
    39
    Default Re: Need help with Renard SS24
    Have you looked a the troubleshooting WIki page? https://www.doityourselfchristmas.co...he_Renard_SS24
    https://RudolphSearch.com - Making it easier to find info across the Christmas Light forums!
    Mooresville, NC
    7,547
    I will look at this closer when I get home, but for RS232, you need a jumper on JP1
    http://www.doityourselfchristmas.com...nard_SS_boards
  4. Likes TazChaLet liked this post
  5. #4
    Winter Haven Florida
    3,039
    ok your saying you made the rs232 adapter but you have a pin on jp2 which is for rs485 is this the adapter you converted
    James WinterHaven Fl
  6. #5
    Jan 2019
    Dallas, TX
    16
    Quote Originally Posted by superdave View Post
    I did but my guess the previous owner already stated it has been working. I just jump to to see how it works.
    Sorry I missed type, I did the RS485 not the RS 232. However, I can't tell the cable is good contact to the pin. The new USB converter is on the way so I will tell my DIY is good or bad.
    TIA Wayne.
    I did RS485 not the RS232. Sorry for mistype. I just updated the thread.
  7. #6
    3,039
    have you created a element in vixen and patched it to the controller? if so! have you tried to make a sequence and test the controller to see if lights work?
  8. #7
    Jan 2019
    Dallas, TX
    16
    I did create an element in vixen and patched, just 12 channels with 11 patched. See images. Also, I created a test sequence to see if lights come on but no lights On.
  9. #8
    3,039
    did you program the chips yourself? maybe the person you got it from was running them on different baud rate maybe 115200 I know this is what mine are programmed at.
  10. #9
    Jan 2019
    Dallas, TX
    16
    I didn't program the chips, I got it from the user here and plugin and test it out. I did try it at 115200 but didn't see anything. I will give it a try with different converter tonight when my new converter arrive.
  11. #10
    3,723
    If you are using Vixen 3 and have the controller is properly configured, then Vixen will be sending data 100% of the time (even when a sequence is not playing). This is important because it means that when you connect the controller to the PC and get the wiring right you will get either a green RX led lit (you have it set up correctly) or the yellow FE (frame Error) LED. If you get the yellow LED then you start playing with baud rate and swapping D+ and D- until you go green. Most common data errors are bad baud rate and if this is the first cable you have made then getting the data lines swapped. If neither light comes on then the data cable is using the wrong wires or you have selected the wrong serial adapter in Vixen.
