Results 1 to 2 of 2
Thread: Vixen + Arduino+ Relay + Pixel HELP!
    Dec 2018
    1
    Default Vixen + Arduino+ Relay + Pixel HELP!
    Hey,
    Does anyone have a working arduino code that accounts for both relays and pixels? I'm new to vixen and just can't seem to manage to integrate them both!
    Thanks!!
    Hicksville, New York
    102
    Default Re: Vixen + Arduino+ Relay + Pixel HELP!
    Pretty sure you do not need Arduino to control pixels. You will need a separate controller. There must be a reason why no one has done a controller for pixels with Arduino. Probably because of efficiency. You can add the Generic Serial for the Arduino in Vixen for the relays which is what I did. Then add the pixel controller. If you have a pi, you can get the Falcon Pi Hat for $35 to run your pixels. (If you don't have a lot.) I would use Falcon Pi Player if you have a pi laying around to control the Arduino and the Hat (For Pixels.)
    For the Arduino, I am using this code to communicate with Vixen and the relays. Just change the code for the mega or Uno. Then your channel count and what pins you are using.
    Code:
    #define MEGA_VIXEN
    //#define UNO_VIXEN
    #ifdef MEGA_VIXEN
      #define MAX_CHANNELS 8
      //int channels[MAX_CHANNELS] = {2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53};
      int channels[MAX_CHANNELS] = {2,3,4,5,6,7,8,9};
    #endif
    #ifdef UNO_VIXEN
      #define MAX_CHANNELS 18
      int channels[MAX_CHANNELS] = {2,3,4,5,6,7,8,9,10,11,12,13,A0,A1,A2,A3,A4,A5};
    #endif
    #define TimeOut 5000L  //time out of 5 seconds for serial data check.
    int incomingByte[MAX_CHANNELS];
    unsigned long time_check = 0;  // Used to check time if  Vixen data received.
    void setup()
      int i;
      int j;
      Serial.begin(9600); // set up Serial at 9600 bps
      for ( i = 0; i < MAX_CHANNELS; i ++ )  pinMode(channels[i], OUTPUT);
    time_check = millis();  //get the time.
    void loop()
      int i;
      int j;
      if (Serial.available() >= MAX_CHANNELS)
        for (i=0; i < MAX_CHANNELS; i ++) {    incomingByte[i] = Serial.read();
           if (incomingByte[i] > 0) time_check = millis();  //get the time.
      for (i = 0; i < MAX_CHANNELS; i ++ )    analogWrite(channels[i], incomingByte[i]);
      if (millis() - time_check > TimeOut) {
         //Turn all lights on
            for (j=0; j < MAX_CHANNELS; j++) {
              incomingByte[j] = 255;
    Here is a little diagram map of what I am trying to say.
