Results 1 to 2 of 2
Thread: Sub parts for SSRneon-G2LED
    Jan 2008
    Clarksville, TN
    304
    Default Sub parts for SSRneon-G2LED
    Going through some old boxes I came across some SSRneon-G2-LED boards I never assembled.
    The LED listed in the BOM is obsolete, has a operating voltage of 2.5 V max (2 V typ) . I am looking to use an LED with a 1.9-2.1V forward voltage range. I just wanted to verify that I do not need to change the 220 ohm (R1-4) or the 680 ohm (R9). According to my math, I don't believe I do, but wanted to check with the experts.
    Thank you,
    Tony
    Tony
    Live since 2007
    Putting the Yule back into Yuletide
    Springville, Utah
    554
    Default Re: Sub parts for SSRneon-G2LED
    You should be OK. With the 2.5v LED and 680 ohm, it's drawing about 3.7ma. With the newer LED you'd pull around 4.5ma, still well within most LEDs current capacity.
    Jimboha
    Springville, Utah
  3. Thanks ChiefWarrant thanked for this post
