Results 11 to 17 of 17
Thread: usb3 to rj45 dongle
    Dec 2015
    Saint Louis
    169
    Default Re: usb3 to rj45 dongle
    Hereís the one I used. Only $7. I did have to sacrifice an old ethernet cable to finish it off though.
    Ken
    JBtek USB to RS485 Converter Adapter ch340T chip 64-bit Window 7 Supported https://www.amazon.com/dp/B00NKAJGZM..._nU4nCb1MWCXTN
    2016 - Static Light Show
    2017 - 72 Renard Channels - Roughly 4,200 Lights - 3 Sequenced Songs
    2018 - Added Pixels to Rooflines
    Website: www.doyonlights.com
    You Tube: https://www.youtube.com/channel/UCQ8...yLJieEEwDto7xg
    Adding Pixel Arches, Snowflakes, and Singing Bulbs in 2019!
    Jan 2018
    192
    Quote Originally Posted by kdoyon View Post
    Clicking the link through to their shop, shows that this one is no longer available. Not sure if itís true or not.
    Ken
    Here ya go.
    http://renard-shop.com/home/66-usbrs485-adapter.html
    Springville, Utah
    536
    You can make a customer adapter to Renard pinout, or use this type of connector:
    RS232-DB9-Male-Female-Plug-Connector-RJ45-Female-Ethernet-Adapter You do the pinout rewiring internal to the adapter.
    I used to use these before I stare using an e1.31 bridge.
    Jimboha
    Springville, Utah
    Ashburn, VA
    394
    Quote Originally Posted by Mudsculpter View Post
    Jerry-Rigs
    click on the second one again i copy/pasted the wrong link
    Ah, now I see.
    Yes. Ditto on the custom cable but that's not a big deal.
    It claims to use an FTDI chip. That is a solid industry standard chip that got a bad rap a few years ago in the DIY community because some systems integrators and vendors inadvertently used a counterfeit FTDI chip. To combat counterfeiters, FTDI changed their drivers to detect and not work with counterfeits. That left a huge bad taste in a lot of mouths about FTDI (not so much about the counterfeiters). The SI's and vendors took it on the chin for using a chip from such an "uncaring" manufacturer. In case it is not clear, I strongly support FTDI.
    Ashburn, VA
    394
    Since a custom cable is required anyway, this could be an interesting option. Not required, just interesting.
    Jan 2018
    192
    The one from Renard requires no custom cable.
    Powder Springs, GA
    1,146
    Thanks for all the info. Its coming back to me now.
    If you are not a supporting member please consider Becoming an Active Member
