Results 1 to 10 of 17
Thread: usb3 to rj45 dongle
    Powder Springs, GA
    1,146
    Default usb3 to rj45 dongle
    Getting back into Christmas lighting display after a few years off. Planning on making a few changes to my setup and wondering if anyone has used this product to simplify the connection to the renard controllers..
    https://www.amazon.com/gp/product/B0...9V9Z34M7&psc=1
    Or this
    https://www.amazon.com/RS-485-RS-422...to+RS485-RS422
    If you are not a supporting member please consider Becoming an Active Member
    3,717
    Default Re: usb3 to rj45 dongle
    That first device outputs Ethernet. Renards do NOT take Ethernet as an input.
    For the 2nd one, you would need to make a custom cable to adapt the pinout on the device to the pinout needed by the Renard controller.
    Ashburn, VA
    394
    I'm not sure how this device helps you connect to a Renard controller.
    Renard devices are serial and speak Renard protocol over a physical RS-485 connection.
    The SS boards (and others maybe) can be flashed to speak DMX512 protocol over a physical RS-485 connection with a different pin-out.
    It is typical to use a USB to RS-485 dongle to connect a PC to a Renard controller.
    The device you reference is not a USB to RS-485 dongle, it is a USB to Ethernet (AKA: Internet) dongle. It will not work and may even break the dongle or the Renard.
    Ashburn, VA
    394
    I think both of his links are to the same device. The first link is an Amazon listing. The second link is just the picture from the Amazon listing. I see no second device.
    Powder Springs, GA
    1,146
    I really didnt think the first device would work but needed to ask but since the second connector stated that it was a usb to rs485... thought it might work. thinking of using a laptop instead of my show computer.
    Powder Springs, GA
    1,146
    Jerry-Rigs
    click on the second one again i copy/pasted the wrong link
    3,717
    the 2nd link worked for me and my response is the same. a custom cable will be needed to use that device.
    Apr 2011
    Redding Ca
    302
    Jan 2018
    192
  10. Likes TazChaLet liked this post
  11. #10
    Dec 2015
    Saint Louis
    169
    Clicking the link through to their shop, shows that this one is no longer available. Not sure if itís true or not.
    Ken
    2016 - Static Light Show
    2017 - 72 Renard Channels - Roughly 4,200 Lights - 3 Sequenced Songs
    2018 - Added Pixels to Rooflines
    Website: www.doyonlights.com
    You Tube: https://www.youtube.com/channel/UCQ8...yLJieEEwDto7xg
    Adding Pixel Arches, Snowflakes, and Singing Bulbs in 2019!
