Results 11 to 17 of 17
Thread: Arch strip recommendations
    Jan 2018
    5
    Default Re: Arch strip recommendations
    Just to say thanks for this whole thread - am planning some 12v arches and would have stumbled straight into all kinds of confusion with this one
    May 2016
    228
    You'd have found it eventually. There's a walkthrough video by Matt Johnson on building a HDPE arch in this section somewhere and it gives you the specs on everything you need. To make my arches, I decided on the size of arch and then had Ray make me strips that were about 3 inches short of the arch length. I inserted the pex into PVC tees, drove a screw through the "center" of the tee into the pex, then drilled two holes in two remaining sides of the tee and secured them to the ground with landscape nails. They were solid and didn't need any fancy bases or braces for them.
    309
    Yup, no fancy bases/braces needed. I think you just need to be mindful of two things: how am I going to disassemble for repair (and storage), and how am I going to keep these waterproof.
    9
    When I built my arches I experimented with the two types of strips. I used HDPE tubing in my arches. The single rgb didn't look good. The colors all blended together. The three rgb strips look really good, the color bands are narrow but the individual colors show through without blending together.
    Nov 2014
    Close to Hillsboro, OR
    379
    Quote Originally Posted by TSL View Post
    Are you saying that the 1 IC: 1 LED combo didn't look good, but the 3 LED : 1 IC did?
    9
    Yes. I did not like how the single rgb looked. I felt the three per had a much better look, which is what I went with and I have been very happy with the look.
    9
    The tubing diffused the single rgb color too much for my liking. With the three there are distinct color differences. And the colors are much more vibrant. The single rgb the colors blend together for an almost dirty looking color band.
