Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Buellton Lights 2018 Walk Behind
    Oklahoma City, OK
    58
    Default Re: Buellton Lights 2018 Walk Behind
    How did you mount the Ray Wu milky star modules to the 1x6 redwood?
    Chesapeake, VA
    761
    Nice display! Lots of ideas you gave me for next year! ��
    [SIZE=3][B]8000 + E1.31 Channels (5x E68x controllers)
    128 Renard Channels[/SIZE][/B]
    sequencing with LightShow Pro 2.8 and/or Vixen 3 (using xLights scheduler)
    2 x Pixel Mega Trees, RGB Pixel Roofline, 2 x RGB Pixel Spinners, 11 x Pixel Bushes, 6 x GECE Icicle Arches, 16 x RGB Mini Trees, 2 x Vertical Pixel Poles,
    12 x 10w RGB Floods, 160 Strobes controlled by Arduino
    [URL="http://www.controlthelights.net"]http://www.controlthelights.net[/URL]
    Nov 2012
    Beaumont, Ca.
    8
    What is the black sleeve that you are running you power injection wires in? Is it UV resistant?
    Buellton, California
    366
    Quote Originally Posted by Cdanna77 View Post
    Very nice walk through. How did you model the mini trees, looks like you got pretty even spacing going around the trees in a spiral wrap. I was torn between how you wrapped yours or making them with even straight lines up and down, kinda like a mega tree.
    Thanks, the trees are modeled in Xlights as a tree with 13 spiral wraps. I didnt spend a whole lot of time making sure the spacing was equal on them. A little disorder and uneven spacing isnt a bad thing with an all pixel display. I chose spiral wrap because it seems a bit more traditional. I dont need 62 mini trees/matrices
    366
    Quote Originally Posted by Kensington View Post
    The 3000w Meanwells only run on 220v, correct? If so, did you have a 220 line on site already (like other than a dryer circuit)?
    I have a 100amp 240v subpanel for the display. I also rob power from a couple 240v AC disconnects with dedicated 50a circuit
    366
    Quote Originally Posted by dmadesign View Post
    I think you're referring to the submersible pump cable I use. It has four conductors. I double them up for less voltage drop and higher ampacity most the time. I get old wire free from work. Something like this. https://www.wireandcableyourway.com/...ump-cable.html
    366
    Quote Originally Posted by Cjaqua View Post
    I used small screws, they have holes for mounting
    Nov 2012
    Beaumont, Ca.
    8
    Thanks. That's what I was referring to. From your video it kinda looked like it was just a sleeve that you had over your injection wires.
    Quote Originally Posted by uncledan View Post
    Staten Island New York
    298
    Thank you. I’m going to mock one up and check it out. I liked some of the effects you got with them.
