Results 1 to 6 of 6
Thread: too many outputs
    Nov 2018
    9
    Default too many outputs
    Newbie to Vixen and trying to use serial "controller" to talk to an Arduino UNO.
    Works fine for 6 monochrome LEDs, but when I updated my experiment to 4 RGB (12 elements) and tried to add 6 more elements to the serial controller list, I get and error "too many outputs".
    Considering I'm planning 336 outputs, this is not a good sign. Any reason why it is telling me this?
    (On my current Arduino-driven display, I can control the 336 "elements" by using 7 I2C control boards)
    3,357
    Default Re: too many outputs
    You need to increase the number of outputs you defined in the controller setup. Be aware that refresh rate and Serial baud rate are important factors when determining how many channels a serial interface can support. You need to run the interface fast enough to get all of those channels to the controller within one refresh frame. 25ms is the real motion rate. If you are not doing real motion then many people use a 50ms frame rate. To me a 100ms frame rate is too choppy,
    13
    Gentlemen I have tried ever ones commands for the Audrin0 and non of them seem to be working. does any one have a complete working program for audrino.
    3,357
    The place I told you to change a setting is on Vixen. You need to increase the number of outputs on the Vixen serial controller configuration.
    Southern California
    767
    Quote Originally Posted by shaclayc View Post
    I suggest you try the sketch by Victor_PV found here http://doityourselfchristmas.com/for...th-Random-mode
    It requires that you set the outputs to your nunbers.
    Also, what part of L A do you live in? I am in North Orange county.
    Kevin
    13
    Kev
    I live in the San Fernando valley
