Results 1 to 10 of 18
Thread: Really Big Lights - Replacements
    GA, USA
    60
    Default Really Big Lights - Replacements
    I have decided I want about 10 white RBL's only learn they went out of business early this year. Does anyone know a replacement to them?
    Figure this was the best place to ask.
    Columbus GA, USA
    Aug 2013
    Madison, AL
    279
    Default Re: Really Big Lights - Replacements
    Home Depot carries a knock off of the RBL. They are actually on clearance right now for $5/ea.
    https://www.homedepot.com/p/Home-Acc...3689/305025779
    Keith
    GA, USA
    60
    Sweet thank you.
    Columbus GA, USA
    Ontario, Canada
    2,099
    Same ones are available at HD in Canada, I collected 30 in the Ottawa area over the last few days.
    Ive created a 3D print, revision 8 is printing as I type this, I will post the .stl file on Thingiverse once I confirm the thread pattern matches.
    The RBL 3Dprinter models for pixel conversion will not work with this knock off.
    Cheers!
    Steve
    Learn 1 new thing everyday.
    "AURBO" -- Aurora Borealis
    My weather today
    Sep 2009
    6
    Home Depot has dropped them another $1.00. Now down to $3.98
    Columbus, OH
    4,259
    Has someone done a side by side comparison of these HD units and the original RBL's?
    Ontario, Canada
    2,099
    I do not have an original RBL, but importing the pixel conversion models into TinkerCad shows them to be about 1/2" smaller in diameter at the thread mount compared to the knock offs.
    scaling up the RBL conversion model does not work as it scales the threads too, hence the reason I'm building the conversion from scratch.
    Cheers!
    Steve
    My weather today
    May 2010
    ottawa , ontario, Canada
    1,742
    Quote Originally Posted by Aurbo99 View Post
    that why i cannot find any anymore ..you took them all ...
    cheer
    Washington State
    167
    Just sent my wife out into the wild to bring back a couple of these. the have ball-shaped ones to boot!
    Northern California
    1,059
    The easy conversion of the original RBL (cut off the plastic bulb mount and screw an amusement park dome through the hole) won't work on these battery powered indoor lights.
    So some of the 3D printer folks are doing their own mods. I'm thinking about alternative ways to convert them, as I don't have that tool or skillset yet. One can remove the center post of the new ones (as well as batteries and PCB), but the hole left is smaller. Find appropriate flat modules, or cut off all or part of the theaded "stem" of the amusement park modules and hot glue?
    These new ones have a folding hook; I hope the hinge pin doesn't rust in the rain; since these were designed for indoor use, they had no need to make it weather resistant.
