Results 31 to 36 of 36
Thread: Can you install FPP on a Pi Zero W without another Raspberry Pi?
  1. #31
    4,928
    Default Re: Can you install FPP on a Pi Zero W without another Raspberry Pi?
    It looked odd to me that the WiFi driver was set to external when the PI Zero has internal WiFI.
  2. #32
    Dec 2019
    330
    Are you guys using the pi zero as your main FPP player?
  3. #33
    SF CA
    603
    Quote Originally Posted by Glycerine View Post
    My Master Pi is a P3b, but it only drives the audio/video (no pixels). All my remotes (driving the pixels) are PiZero--7 total PiZero in my show.
  4. #34
    Folsom, CA, USA
    2,272
    Driver options are only: External or Linux Kernel . . . no other. Martin: driver, not WiFi.
    In Lights Therapy
  5. #35
    Folsom, CA, USA
    2,272
    Quote Originally Posted by OzAz View Post
    Hi I can not get my Pi Zero w to connect to my WiFi router
    Have loaded and installed fpp and can log into it when I am tethered via USB port (192.168.7.2 or via fppzero (I renamed the Hostname as I also have a Pi3B+))
    I have put in the SSID and password of my WiFi
    Have set everything to just DHCP
    However when I just power it via the power input, it doesn't connect to my WiFi
    My router gateway is 10.0.0.138
    Attached photo has password temporary removed for privacy
    What the heck am I doing wrong? Anyone help me get the wifi working please
    Attachment 42872
    Appears you are not using the latest release. Maybe should start by loading Release 4.6.
    Release 4.6: https://github.com/FalconChristmas/fpp/releases/tag/4.6
    For your Pi re-image with: FPP-v4.6-Pi.img.zip
    In Lights Therapy
  6. #36
    Folsom, CA, USA
    2,272
    Pi Zeros can be a main player, but a Pi3 or better yet a Pi4 will work much better. For me, the pi Zero is to slow for me to be patient with. I benched all but one of my Pi Zero & Pi Zero W's about October last year.
    Since you have one (Pi Zero.) Work with it, and once you have learned the FPP system; see if the added expense of a 3 or 4 is worth it to you.
    Try using host name over IP. Format for host on my system would be: FPPzero.local
    Also FPP has been problematic for many who use special character. If you can, stick with letters (caps and not) and numbers.
    In Lights Therapy
