Results 21 to 30 of 36
Thread: Can you install FPP on a Pi Zero W without another Raspberry Pi?
    Nov 2018
    Houston, Texas
    2,077
    Default Re: Can you install FPP on a Pi Zero W without another Raspberry Pi?
    So many days reading an flashing and setting and reading and re-flashing ect ect
    Only light I can get to work is the power light
    My guess is my settings are off cause I went through the wiki set up.
    Nov 2018
    Houston, Texas
    2,077
    Just wanted to share a find for the pi zero wh as I haven’t seen it before has the RJ45 and other connections.
    Nov 2018
    Houston, Texas
    2,077
    Finally got FPP playing sequences from my pi zero to the pixel sticks was so ready to throw it in the trash thanks
    SF CA
    603
    What step did you get confused, or have trouble, with?
    You already had FPP running on the Zero several weeks ago.
    Nov 2018
    Houston, Texas
    2,077
    Before I was trying to get the board you sent me working but I couldn’t get anything to light up so now I just have the pi running ( by itself no hat ) my other pixel sticks .
    SF CA
    603
    Did you enable Pi Pixel Strings?
    Nov 2018
    Houston, Texas
    2,077
    Not sure what all I did really lol
    NSW, Australia
    21
    Hi I can not get my Pi Zero w to connect to my WiFi router
    Have loaded and installed fpp and can log into it when I am tethered via USB port (192.168.7.2 or via fppzero (I renamed the Hostname as I also have a Pi3B+))
    I have put in the SSID and password of my WiFi
    Have set everything to just DHCP
    However when I just power it via the power input, it doesn't connect to my WiFi
    My router gateway is 10.0.0.138
    Attached photo has password temporary removed for privacy
    What the heck am I doing wrong? Anyone help me get the wifi working please
    SF CA
    603
    How do you know it’s “not connected to your network” vs “not able to find it”?
    Does the PiZero still go into tethering mode?
    NSW, Australia
    21
    Well I can't see it on my network, either on my routers webpage or using Fing.
    I also tried setting a static IP and I can't access or see that either - router doesn't see it, Fing doesn't see it, cant ping it...
    It appears as if the WiFi is just not on, or not working on the Pi
    The pi only goes into the USB tethering mode, can NOT tether via wifi
