Results 1 to 4 of 4
Thread: Mega Tree Information
    Nov 2012
    Wenatchee, WA
    447
    Post Mega Tree Information
    I have posted this picture enough times that everyone is probably sick of seeing it.
    I've had a few inquires on information on the trees so here it is for anyone who might be interested.
    I will refer to these as Large (the center tree) Medium (the two on each side of the center tree) and Small (the two on the outside of the five trees as well as the two "wing" trees closer to the foreground)
    All my pixels are 12v set to 50%
    All trees are 180(ish) degrees
    Pole lengths are to the bottom of the topper
    Large Tree
    35 strings of 120 pixels (4,200)
    Pole 231"
    Base Width 164"
    Boscoyo ChromaStar 46" (six ring, 270 pixels)
    HolidayCoro QT3 Topper using outer rows
    6 350 watt power supplies
    1 400 watt power supply for star
    Each string powered between the 100 and 20 pixel sections about 4ft up the string from the bottom.
    F16v3 using 10 main board ports 480 pixels (4 strings) per port
    F16v3 has four output differential expansion board on it (two outputs to each medium tree)
    Medium Tree
    25 strings of 82 pixels (2,050)
    Pole 160"
    Base Width 110"
    Boscoyo ChromaStar 36" (six ring, 270 pixels)
    HolidayCoro QT3 Topper using inner rows
    3 400 watt power supplies
    Every two strings (164 pixels) has power injection at the bottom
    2 F16v3 receiver boards 492 pixels per port (6 strings) per port
    --Medium trees also share power and outputs with pixel poles on each side of them as well as two 46" ChromaBulbs (not pictured here)--
    Small Tree
    17 strings of 45 pixels (765)
    Pole 89"
    Base Width 61"
    Boscoyo ChromaStar 23" (three ring, 90 pixels)
    HolidayCoro QT2 Topper using outer rows
    1 350 watt power supply
    Every two strings (90 pixels) has power injection at the bottom
    AlphaPix4 using 360 pixels per port.
    96
    Default Re: Mega Tree Information
    Thanks for the info
    Nov 2017
    30
    Do you have any videos?
    Nov 2012
    Wenatchee, WA
    447
    Quote Originally Posted by robbiet View Post
    Not yet, it is a priority for me this year as last year I didnít do really any videos.
