Results 1 to 10 of 12
Thread: Failed Mean Well power supply and questionable diagnostic techniques
    Mar 2017
    Indiana
    145
    Unhappy Failed Mean Well power supply and questionable diagnostic techniques
    I just had a "new this year" Mean Well NES-350-5 300W 5v power supply fail. It's in my garage, so it's protected from weather and temperature doesn't drop below 40.
    Here's what I did to try to figure out the issue (and/or make it worse). I don't think this is the recommended way to figure it out, but I'm open to suggestions for next time.
    • Tried unplugging and plugging back in the supply with and without load. The green indicate LED did not come on at any power.
    • Opened power supply to inspect for blown components or expanded caps or just anything odd, but didn't see anything.
    • Pulled internal fuse and checked continuity with multimeter. Failed continuity! A first sign of a failure.
    • Decided to wrap foil around fuse (I don't think this is a recommended diagnostic technique)
    • Prepared for something to happen, then plugged in the power supply
    • SNAP / SPARKS
    • Quickly unplug the power supply
    • Green thermistor RTH1 blew apart
    At this point, I'm not sure if that's a sign that the thermistor was the problem or just a symptom of an issue downstream. I've ordered a replacement power supply to swap in, so I should have things back soon. I'm trying to decide if it is worth trying to replace the failed part or just give up on the power supply.
    Halloween 2020 Lights: https://youtu.be/Wdxp-NLkkaE
    Christmas 2019 Lights: https://youtu.be/e9qOPoaFV6w
    Other shows and behind the scenes: https://www.youtube.com/channel/UCg1...c85-wgbnkNiLOw
    SF CA
    544
    Default Re: Failed Mean Well power supply and questionable diagnostic techniques
    Did you have 240/115 input selected properly?
    Mar 2017
    Indiana
    145
    Set to 115. Has been running things well for the last few weeks. Came home tonight and part of the show was down.
    SF CA
    544
    When it blew, were any of the outputs connected (ie downstream short)?
    Mar 2017
    Indiana
    145
    I had disconnected everything from the power supply downstream. Whatever is/went wrong is just involving the power supply.
    Nov 2017
    143
    Never. EVER. bridge a fuse! They are popping for a reason!!
    Oct 2010
    NW Suburbs of Chicago
    149
    I bridged plenty of fuses, makes troubleshooting downstream a lot easier , see what smokes, replace
    Mar 2017
    Indiana
    145
    Quote Originally Posted by DrewDennis View Post
    Quote Originally Posted by mikel3332 View Post
    This was my dilemma. If you don't bridge the fuse, how can you diagnose an issue downstream without power? I made sure to disconnect everything else before trying it to minimize the damage. If I put a new fuse it, it seems likely to blow again quickly.
    Jun 2015
    76
    you can replace the fuse by wiring in an incandescent light bulb, if there still a short, the light gets bright, it's likely there was a voltage spike and cause the thermistor to short to do its job(burn the fuse), sometime it's easy as replacing it to fix the issue.
    Las Vegas, Nevada, U.S.
    2,156
    I would do a sanity check first, on the output check for a dead short (ohm meter). Do the same for all voltage rails that thermister exploding like that means a large fault or your on the edge of its capability for a long time.
    What is your expected current draw/ or better yet tested load?
    Is the load under 80% of my power supply wattage?
    With it off you can also do a ohm test between the power rail inside the power supply basically ohm test across the major capacitors. (make sure to short them first to discharge.) If you find a short you want to remove capacitors till the short goes away. Then replace and put back working components
    You can do a diode test but you often have to remove them from circuit to test.
    Your most likely failure is ether a diode or a capacitor to cause that thing to pop.
    Projects:
    Videos
