Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: LED "flutter"
    Southern California
    897
    Default Re: LED "flutter"
    Duplicate
    Kevin
    Southern California
    897
    Victor_PV sketch uses a header. You can find the sketch on this site. If you use it, it already has the digitalWrite code in it. You would add a header of ~! to the header dialog box in the Vixe n controller section (where you adjust the band rate). A lot of people use the Victor sketch.
    http://doityourselfchristmas.com/for...th-Random-mode
    Kevin
    Nov 2018
    12
    So, being unable to eliminate the "flutter" for my Christmas display, I removed my newly-constructed Arduino control box and plugged my lights directly into the wall outlet. There was no flutter in any of the lights. This leads me to think perhaps my 5v/2amp power transformer was the source of the flutter. I'm just wondering what other members of this forum think is the likelihood that investing in a better power transformer would eliminate the undesirable flashing of lights when I am switching them on and off through my control panel. The 110 voltage is the same either way, the difference being I have a POSSIBLE culprit in the transformer. Possible?
    Southern California
    897
    Quote Originally Posted by empac99 View Post
    I'm running 2 Sainsmart 8 channel SSR's. I don't see other distinguishing markings on them.........
    Upon re-reading this thread, I just noticed that you are using the Sainsmart SSR's. If you have the $20 version of the SSR's, they can not dim correctly. Sainsmart has a newer SSR listed on their site for $42 that may dim, but I don't know as I have never used them.
    A short video of the "flutter" might help us.
    Kevin
    4,065
    And at what brightness do they flutter? Create a sequence that cycles through Full on dimming to off and then back on over a 10 sec period. Most likely you ar only outputting a quick pulse to the SSR. For LEDs you need to have the SSR signal on for the entire on period.
    4,065
    DirkCheap SSRs or any of the other AC SSRs on this site are less expensive per channel and do dimming very nicely.
