Thread: Ghosts in the Machine
    Chambersburg, PA
    703
    Default Ghosts in the Machine
    I have channel specific flashing of incorrect channels. For instance when a certain pixel on my pixel tree is lit RED, the Blue channel on my Renard RGB arch lights. The Arch channel is 99 and the Pixel Tree channels are 688-2920.
    There are a couple of other similar Ghosts showing up in my Renard channels when my pixel tree is in operation, all seem to be in Dumb RGB channels, but on different controllers. Also the channels that are misfiring are not responding to their channel number. All this equipment was tested in component level less than a month ago and worked perfectly. This EXACT same issue plagued me last year without resolution.
    I am using FPP from RPi > Falcon F4V > serial output to Renard Daisy Chain : RP32>RP32>RP32>64LSD>64LSD>Ren64 The problems are showing up in the last three controllers in the daisy chain.
    I am using the current version of xLights
    What additional info can I provide or what suggestions do you have for me to check?
    2016 - No Display
    Nov 2018
    14
    Default Re: Ghosts in the Machine
    did you tried to re-arrange the controllers to narrow down the issue, if that is controller specific?
    Chambersburg, PA
    703
    Quote Originally Posted by priyankchouksey View Post
    I can't rearrange the controllers and not mess up my show. Also I did a full test of the controllers in my workshop and they worked fine. this is the exact same behavior I saw last year.
    2016 - No Display
