Results 11 to 20 of 21
Thread: My first 3D design for Arch bases, includes 3" PVC mount/elevated cable compartment
    Mar 2011
    Arlington, TX
    95
    Default Re: My first 3D design for Arch bases, includes 3" PVC mount/elevated cable compartme
    I haven't played with carbon fiber yet. I am waiting to see how these hold up this year. I am a bit dis-appointed in the life span of HDPE. The UV rays really get to it and I need to replace them every two years.
    Long Island, NY
    7,678
    I like how you hid the electronics inside the candy cane tube. Nice.
    Morrisburg, On, Canada
    2,540
    What software did you use to design the base?
    Mar 2011
    Arlington, TX
    95
    Autodesk Fusion 360
    Nov 2017
    142
    Did you get a chance to upload this to thingiverse?
    64
    any chance this fits 1" Pex? i'm looking into a dual arch support for 1" pex. theres one on thingiverse but its for 3/4.. dont ask me how i know
    Mar 2011
    Arlington, TX
    95
    I used 1 inch HDPE pipe from a plumbing supply, outside diameter is a little shy of 1 1/8". Sharkbite has the same dimension. The inside diameter of my base pipe tube is 1 1/8 inch. I did sign up for a ThingaVerse account and uploaded my files. I have to wait 24 hours to publish it since I was a new member. As soon as I publish, I will replay with link.
    Jan 2018
    231
    I would like to print this up, however I only need the 1 for the psu, did you design for just the base and end pieces as well?
    Mar 2011
    Arlington, TX
    95
    The top, where the power supply and esp are mounted, is a separate piece that is attached to the base. I only printed the top part for where I needed the power supply and control and just the base for the rest of them. I did not design a specific base for the last arch in the series (for one arch end). The base includes the raised floor and the 3 inch tube to slide a 3 inch pvc pipe on. The top part is 7 inch by 2 inch (the flat side on inside) with an outside curve to match the 3 inch pipe. The holes in it were designed specially for a Meanwell 25S power supply and a ESPixelStick.
    Mar 2011
    Arlington, TX
    95
    Link to 3D files on Thingaverse
    https://www.thingiverse.com/thing:3355028
