Results 11 to 20 of 23
Thread: Issue with element turning off at wrong time
    Nov 2018
    16
    Default Re: Issue with element turning off at wrong time
    Quote Originally Posted by FrozenNightmare View Post
    No i did not. I simply copied the code. I'm not sure how to make those changes.
    Sent from my SM-G930T using Tapatalk
    Ok. I figured that out and added the header box. It's doing the same thing. Very odd...
    Nov 2018
    16
    Here is a video of what I'm working on. You will see Jack Skellington's face working. Then towards the end of the video it starts to go wrong.
    https://youtu.be/Eb5ZSp5Hznc
    (It really gets bad at the end of the song, but that is not in this video). The eyes and nose should stay on the entire time (once he turns on). They seem to shutoff or blink when other effects do.
    Thanks again for the help
    Southern California
    796
    "It's doing the same thing". Do you mean doing the same thing with the Victor sketch? If so, you may have a problem with the sequence, not the sketch.
    Kevin
    Nov 2018
    16
    Yes. It is doing the same thing with the Victor sketch. If I set a plug for set level. It should stay on? It's flickering with other plugs.
    3,528
    are you playing the show using vixen or fpp? If vixen, do you have more then one copy running?
    Nov 2018
    16
    From Vixen. Only 1 copy playing
    Southern California
    796
    OK. so with two different sketches it is doing the same thing. That leads me to think that you have a hardware problem such as SSR. Or you have a sequencing problem.
    What type of SSR are you using? Are you powering them with a separate power supply? Do you have all of the DC grounds tied together?
    What about the MEGA, how are you powering it? If by the USB cable, you might want to try powering with a separate power supply.
    A couple of pictures of your setup might help.
    Kevin
    Nov 2018
    16
    Great info. Thanks! I am not currently home till tomorrow night for pictures. But i am powering x2 - 8 channel relays with power supply from same power supplying 16 plugs.
    The arduino is powered from USB only. I try adding a power supply to arduino, and a separate power supply for relays. And let you know if that worked in a couple days.
    Thanks again!!
  9. #19
    Nov 2018
    16
    Thanks again!!
    I added separate power supply for relays and a power supply to arduino. No change to the issue. All DC grounds tied together on relays.
  10. #20
    Southern California
    796
    you are only using 16 channels (2x 8ch ssr) but your first sketch is setup for 48 channels. Try reducing the defined number of channels in your sketch.
    Kevin
