Results 1 to 10 of 23
Thread: Issue with element turning off at wrong time
    Nov 2018
    16
    Default Issue with element turning off at wrong time
    Hello all,
    I am fairly new to this. I am using an Arduino Mega hooked up to x2 - 8 channel relays. Using a total of 16 plugs, and only running basic LED christmas lights.
    The issue I am having on a few sequences is that I will have (for example) Plug 3 will be on "set level" solid for a long period of time, however it will turn off when another plug is activated (also at set level). Any ideas?
    Here is the code I am using if it helps.
    HTML Code:
    #define MEGA_VIXEN
    //#define UNO_VIXEN
    #ifdef MEGA_VIXEN
      #define MAX_CHANNELS 48
      int channels[MAX_CHANNELS] = {2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53};
    #endif
    #ifdef UNO_VIXEN
      #define MAX_CHANNELS 18
      int channels[MAX_CHANNELS] = {2,3,4,5,6,7,8,9,10,11,12,13,A0,A1,A2,A3,A4,A5};
    #endif
    int incomingByte[MAX_CHANNELS];
    void setup()
      int i;
      Serial.begin(57600); // set up Serial at 57600 bps
      for ( i = 0; i < MAX_CHANNELS; i ++ )  pinMode(channels[i], OUTPUT);
    void loop()
      int i;
      if (Serial.available() >= MAX_CHANNELS)
        for (i=0; i < MAX_CHANNELS; i ++)      incomingByte[i] = Serial.read();
      for (i = 0; i < MAX_CHANNELS; i ++ )    analogWrite(channels[i], incomingByte[i]);
    Southern California
    769
    Default Re: Issue with element turning off at wrong time
    you do not have any synchronizing bits. the data can get 'lost'.
    you are using Analogwrite when you should probably be using Digitalwrite.
    you should try the sketch by Victor_PV found here - http://doityourselfchristmas.com/for...th-Random-mode
    Kevin
    Nov 2018
    16
    Thank you. I was looking at Victor's code. However I do not want my lights on random when Vixen sequences are done. I want the lights to stay off.
    Sent from my SM-G930T using Tapatalk
    3,427
    Just remove the end of sequence detection and they will stay the way you leave them.
    Nov 2018
    16
    Sorry again as I am new. How do I do that?
    3,427
    There has to be some code that is tracking when the the last data arrived and starts a timer. The loop must be checking to see if enough time has passed since the last data. Either remove the check or change the wait time to a few days (effectively turning it off).
    Nov 2018
    16
    Thanks for the help. I put Victor's code on the arduino. My lights do not appear to be working with it. The random mode surely works, but not the actual vixen sequences. I changed the vixen speen to 57600 as well to match the code.
    Nov 2018
    16
    Should I be using digitalwrite without using any pixels or led strips. Just normal christmas light strands that are LED.
    Southern California
    769
    If you are not dimming then digitalwrite works. Analogwrite is only for certain output line on the MEGA. Did you add a header to your vixen generic serial controller configuration when you tried Victors code? You need it to synchronize to the data. You need to put ~! In the header box.
    Kevin
    Nov 2018
    16
    No i did not. I simply copied the code. I'm not sure how to make those changes.
