Thread: Mega 2560 code Help Please!
    Oct 2018
    5
    Default Mega 2560 code Help Please!
    I have an issue with the sketch I'm using and need some help to figure out what's going on. I am using a 5V WS2811 pixels system running a simple string on the front of my house. I originally only had 235 pixels but just recently increased it to 349. Now I am an extremely all around newbie at this stuff and only know enough to be dangerous. The sketch worked when I had 235 pixels but now quits in the middle of the sketch when I try to run my new 349 set up. I am currently running the Fast LED Demo program to make sure everything is in order and I do not have any problems with this one or even another sketch.
    So, can someone take a look at this and see what might be causing the issue?
    Thanks a million! I'm still trying to learn this whole sketch and code business and would like to write my own stuff next year.
    Here is the sketch:
    // Mike Joseph - michaelpjoseph@gmail.com - 2016.Oct.26
    // 2016 Arduino Christmas Light display
    // 1x - Arduino UNO Microcontroller
    // 4x - 50 LED WS2811 Strips
    // 1x - 10W 5V Power Supply
    #include "FastLED.h"
    #define NUMPIX 349 // Total LEDs. 200 is probably about max with this code on the UNO. Memory has been almost a constant issue. Need to go Mega if you want more Lights.
    #define LEDPIN 3 // LED control pin
    //PIX struct and array. This is the working array that gets directly manipulated, then the strip_FlushAndDisplay() function flushes it to the fastled array and displays the current strip state.
    struct PIX {
    uint8_t R;
    uint8_t G;
    uint8_t B;
    PIX PIXARR[NUMPIX]; // master array to be dumped to strand on each redraw
    CRGB leds[NUMPIX]; //fastled display array. Not directly manipulated except for in the scdisplay_rainbow() function
    //strip_FlushAndDisplay() - dumps PIXARR to 'leds' fastled display array and then 'shows' current state of strip
    void strip_FlushAndDisplay() {
    for (int16_t a = 0; a < NUMPIX; a++) {
    //strip.setPixelColor( a, PIXARR[a].R, PIXARR[a].G, PIXARR[a].B); // single strand operation
    leds[a] = CRGB(PIXARR[a].R, PIXARR[a].G, PIXARR[a].B);
    FastLED.show();
    //listPIXARR() - debug function to dump current PIXARR state to terminal
    void listPIXARR() { // DEBUG - dump pixel array
    strip_FlushAndDisplay();
    Serial.print(a); Serial.print(": "); Serial.print("\t"); Serial.print(PIXARR[a].R); Serial.print("\t"); Serial.print(PIXARR[a].G); Serial.print("\t"); Serial.println(PIXARR[a].B);
    //initPIXARR_rand() - initializes all LEDs to a random RGB color
    void initPIXARR_rand() {
    PIXARR[a] = { rand() % 255, rand() % 255, rand() % 255 };
    //initPIXARR_null() - sets all LEDs to off
    void initPIXARR_null() {
    PIXARR[a] = { 0, 0, 0 };
    //rndSinglePIX_init() - returns a random single pixel skewed toward either R, G, or B to prevent overly white or pastel looking colors
    PIX rndSinglePIX_init() {
    PIX initPix_buffer;
    initPix_buffer.R = 0;
    int16_t skew = rand() % 3; // 0 - red | 1 - green | 2 - blue
    switch (skew) {
    case 0:
    initPix_buffer.R = 255;
    initPix_buffer.G = rand() % 200;
    initPix_buffer.B = rand() % 200;
    break;
    case 1:
    initPix_buffer.R = rand() % 200;
    initPix_buffer.G = 255;
    break;
    case 2:
    initPix_buffer.B = 255;
    break;
    return initPix_buffer;
    //initPIXARR_snakes() - creates an evenly spaced number of 'snakes' of specified 'length'
    void initPIXARR_snakes(int16_t length, int16_t snakes) {
    if ((snakes * length) >= NUMPIX) { //check for crazy inputs and set fallback defaults
    snakes = 1;
    length = 10;
    uint8_t maxbrightness = 255;
    uint8_t currbrightness = 0;
    int16_t section_increment = maxbrightness / length;
    int16_t section_seperator = NUMPIX / snakes;
    for (int16_t a = 0; a < NUMPIX; a++) { // zero out array
    for (int16_t snake_start = 0; snake_start < NUMPIX; snake_start += section_seperator) {
    currbrightness = 0;
    for (int16_t s = snake_start; s < (snake_start + length); s++) {
    currbrightness += section_increment;
    PIXARR[s] = { currbrightness, currbrightness, currbrightness };
    PIXARR[snake_start + length] = { maxbrightness, maxbrightness, maxbrightness };
    //initPIXARR_sparse() - randomly inits pixels seperated by white space defined by 'spacing'
    void initPIXARR_sparse(int16_t spacing) {
    initPIXARR_null();
    if ((a % spacing) == 0) {
    PIX buffer = rndSinglePIX_init();
    PIXARR[a] = buffer;
    //scdisplay_rainbow() - cycles all LEDs simultaneously through all of the colors for the rainbow for a specified 'duration'
    void scdisplay_rainbow(int16_t duration) {
    int16_t hue = 160;
    for (int i = 0; i < duration; i++) {
    for (int p = 0; p < NUMPIX; p++) {
    leds[p].setHSV(hue, 255, 255);
    FastLED.show();
    delay(10);
    hue++;
    //scdisplay_PopInFadeOut() - self contained display - pops in random pixels, slowly fades them out, the puts it to sleep for a random interval. Loops for 'duration'
    void scdisplay_PopInFadeOut(int16_t duration) {
    initPIXARR_null();
    int16_t delaymax = 1000;
    int16_t curdelay[NUMPIX];
    for (uint8_t i = 0; i < NUMPIX; i++) {
    PIXARR[i].R = 0;
    PIXARR[i].G = 0;
    PIXARR[i].B = 0;
    curdelay[i] = rand() % delaymax;
    for (int16_t a = 0; a <= duration; a++) { //--- main display loop
    if (PIXARR[i].R > 0 || PIXARR[i].G > 0 || PIXARR[i].B > 0) { // decay lit pixels
    if (PIXARR[i].R > 0) PIXARR[i].R--;
    if (PIXARR[i].G > 0) PIXARR[i].G--;
    if (PIXARR[i].B > 0) PIXARR[i].B--;
    //PIXARR[i] = PIXARR[i];
    } else if (curdelay[i] <= 0 && PIXARR[i].R <= 0 && PIXARR[i].G <= 0 && PIXARR[i].B <= 0) { // time to re-initialize pixel
    PIXARR[i].R = rand() % 255;
    PIXARR[i].G = rand() % 255;
    PIXARR[i].B = rand() % 255;
    //PIXARR[i] = PFPIXARR[i].color;
    } else { // decrement delay - unlit pixel for now...
    curdelay[i]--;
    delay(15);
    //scdisplay_PIXVector_snake - self contained display - battles specified # of snakes equally spaced at either end of array. snakes init on the left move right, right snakes move left. collision detection flashes white.
    // right now left snakes are red, right are green for christmas theme.
    void scdisplay_PIXVector_snake(int16_t length, int16_t snakes, int16_t duration) {
    initPIXARR_null();
    snakes = 2;
    length = 5;
    //cout << ".1.\n";
    int16_t maxbrightness = 255;
    int16_t currbrightness = 0;
    // -- setup 10/12/2016 -> can't move to global :/ has to be redefined in each scope
    struct s_PIXVECT {
    uint8_t R;
    uint8_t G;
    uint8_t B;
    int16_t pos;
    int8_t dir;
    bool ishead;
    s_PIXVECT() { // assign defaults
    R = 0;
    G = 0;
    B = 0;
    pos = 0;
    dir = 0;
    ishead = false;
    s_PIXVECT PIXVECT[snakes][length];
    //cout << ".2.\n"; // debug after object creation
    int16_t idx_L = 0; // snake placement indexes for even distribution
    int16_t idx_R = (NUMPIX - 1);
    bool fwddir = true; // bool-alternate direction vectors
    for (int16_t a = 0; a < snakes; a++) {
    currbrightness = 0;
    if (fwddir) {
    int16_t currposition = idx_L;
    for (int16_t b = 0; b < length; b++) {
    //cout << a << " " << b << " forward\n";
    PIXVECT[a][b].R = currbrightness;
    PIXVECT[a][b].G = 0;
    PIXVECT[a][b].B = 0;
    // PIXVECT[a][b].R = a + 10;
    // PIXVECT[a][b].G = a + 10;
    // PIXVECT[a][b].B = a + 10;
    PIXVECT[a][b].pos = currposition;
    PIXVECT[a][b].dir = 1;
    currposition += 1;
    idx_L += section_seperator;
    } else {
    int16_t currposition = idx_R;
    for (int16_t b = (length - 1) ; b >= 0; b--) {
    PIXVECT[a][b].R = 0;
    PIXVECT[a][b].G = currbrightness;
    PIXVECT[a][b].dir = -1;
    currposition -= 1;
    idx_R -= section_seperator;
    fwddir = !fwddir;
    //--- DEEP DEBUG START ---
    // cout << ".3.\n"; // debug after snake placement
    for (int a = 0; a < snakes; a++) {
    //cout << "--- " << a << " ---\n";
    for (int b = 0; b < length; b++) {
    cout << PIXVECT[a][b].R << "\t" << PIXVECT[a][b].G << "\t" << PIXVECT[a][b].B << "\t" << PIXVECT[a][b].pos << "\t" << PIXVECT[a][b].dir << "\n";
    //system("pause");
    //cout << "--------------------------\n\n\n\n";
    //--- DEEP DEBUG END ---
    // --- add iterative stuff here ---
    for (int16_t i = 0; i <= duration; i++) {
    //cout << "---- " << i << " ----\n";
    initPIXARR_null(); //blank out the array
    for (int16_t d = 0; d < snakes; d++) { // draw the snakes to the array - outer object loop
    for (int16_t e = 0; e < length; e++) { // inner element loop
    if (PIXARR[PIXVECT[d][e].pos].R != 0) { // add collision detection here if PIXAR[pos].r / g / b > 0
    PIXARR[PIXVECT[d][e].pos] = { 255, 255, 255 };
    } else { // no collission
    PIXARR[PIXVECT[d][e].pos] = {PIXVECT[d][e].R, PIXVECT[d][e].G, PIXVECT[d][e].B };
    //listPIXARR();
    delay(50);
    for (int16_t m = 0; m < snakes; m++) { // move the snakes
    PIXVECT[m][e].pos += PIXVECT[m][e].dir;
    if (PIXVECT[m][e].pos > (NUMPIX - 1)) {
    PIXVECT[m][e].pos = 0;
    PIXVECT[m][e].dir = 1;
    if (PIXVECT[m][e].pos < 0) {
    PIXVECT[m][e].pos = (NUMPIX - 1);
    PIXVECT[m][e].dir = -1;
    //PIXARR_toWhite() - increment all pixels to solid white
    void PIXARR_toWhite() {
    for (uint16_t w = 0; w < 300; w++) {
    for (uint16_t p = 0; p < NUMPIX; p++) {
    if (PIXARR[p].R < 255) PIXARR[p].R++;
    if (PIXARR[p].G < 255) PIXARR[p].G++;
    if (PIXARR[p].B < 255) PIXARR[p].B++;
    delay(20);
    // scdisplay_PIXVector_linedots - not currently used - looks too similar to my battling snakes in practice
    void scdisplay_PIXVector_linedots(int16_t duration) {
    Serial.println("linedots process");
    int16_t halfway = NUMPIX / 2;
    int16_t dotsep = 3; // decrease for more dots, increase for less
    int16_t numdots = halfway / dotsep;
    struct s_PIXVECT {
    uint8_t R;
    uint8_t G;
    uint8_t B;
    int16_t pos;
    int8_t dir;
    bool ishead;
    R = 0;
    G = 0;
    B = 0;
    pos = 0;
    dir = 0;
    ishead = false;
    s_PIXVECT PIXVECT[NUMPIX]; // every pixel has a vector
    // draw line portion on left side
    int16_t currposition = 0;
    int16_t fadepixels = 3;
    int16_t section_increment = maxbrightness / fadepixels;
    for (int16_t a = 0; a < fadepixels; a++) { // fade left line
    // PIXVECT[a].R = currbrightness;
    // PIXVECT[a].G = currbrightness;
    // PIXVECT[a].B = currbrightness;
    PIXVECT[a].G = 0;
    PIXVECT[a].B = 0;
    PIXVECT[a].pos = currposition;
    PIXVECT[a].dir = 1;
    currposition += 1;
    for (int16_t a = currposition; a < (halfway - fadepixels); a++) { // bright center of left line
    // PIXVECT[a].R = maxbrightness;
    // PIXVECT[a].G = maxbrightness;
    // PIXVECT[a].B = maxbrightness;
    PIXVECT[a].G = 0;
    PIXVECT[a].B = 0;
    PIXVECT[a].dir = 1;
    currposition += 1;
    for (int16_t a = currposition; a < halfway; a++) { // bright center of left line
    currbrightness -= section_increment;
    PIXVECT[a].G = 0;
    PIXVECT[a].B = 0;
    //PIXVECT[a].G = currbrightness;
    //PIXVECT[a].B = currbrightness;
    PIXVECT[a].dir = 1;
    currposition += 1;
    // draw dot portion
    for (int16_t a = (NUMPIX - 1) ; a > halfway; a -= dotsep) {
    PIXVECT[a].R = 0;
    PIXVECT[a].B = 0;
    // PIX VECT[a].G = maxbrightness;
    PIXVECT[a].pos = a;
    PIXVECT[a].dir = -1;
    for (int a = 0; a < NUMPIX; a++) {
    cout << a << ":\t" <<PIXVECT[a].R << "\t" << PIXVECT[a].G << "\t" << PIXVECT[a].B << "\t" << PIXVECT[a].pos << "\t" << PIXVECT[a].dir << "\n";
    system("pause");
    //system("cls");
    for (int16_t d = 0; d < NUMPIX; d++) { // draw the snakes to the array - outer object loop
    if (PIXVECT[d].dir != 0) {
    if (PIXARR[PIXVECT[d].pos].R != 0) { // add collision detection here if PIXAR[pos].r / g / b > 0
    PIXARR[PIXVECT[d].pos] = { 255, 255, 255 };
    PIXARR[PIXVECT[d].pos] = {PIXVECT[d].R, PIXVECT[d].G, PIXVECT[d].B };
    //listPIXARR();
    //system("sleep .005");
    delay(25);
    for (int16_t e = 0; e < NUMPIX; e++) { // inner element loop
    if (PIXVECT[e].dir != 0) {
    PIXVECT[e].pos += PIXVECT[e].dir;
    if (PIXVECT[e].pos > (NUMPIX - 1)) {
    PIXVECT[e].pos = 0;
    PIXVECT[e].dir = 1;
    if (PIXVECT[e].pos < 0) {
    PIXVECT[e].pos = (NUMPIX - 1);
    PIXVECT[e].dir = -1;
    // increments all pixels by one place for clockwise rotating effect
    void incrPIXARR() { // increment all pixels 1 position
    PIX buffer = PIXARR[0], hold;
    PIXARR[0] = PIXARR[NUMPIX - 1];
    for (int16_t a = 1; a < (NUMPIX); a++) {
    hold = PIXARR[a];
    PIXARR[a] = buffer;
    buffer = hold;
    // decrements all pixels by one place for counterclockwise rotating effect
    void decrPIXARR() { // decrement all pixels 1 position
    PIX buffer = PIXARR[(NUMPIX - 1)], hold;
    PIXARR[(NUMPIX - 1)] = PIXARR[0];
    for (int16_t a = (NUMPIX - 2); a >= 0; a--) {
    hold = PIXARR[a];
    PIXARR[a] = buffer;
    buffer = hold;
    // loop incrPIXARR function 'times' times
    void incrPIXARR_looper(int16_t times) {
    for (int16_t a = 0; a < times; a++) {
    incrPIXARR();
    //listPIXARR();
    delay(100);
    //system("cls");
    // loop decrPIXARR function 'times' times
    void decrPIXARR_looper(int16_t times) {
    decrPIXARR();
    delay(100);
    // program setup
    void setup() {
    FastLED.addLeds<WS2811, 3, RGB>(leds, NUMPIX);
    FastLED.addLeds<WS2811, 4, RGB>(leds, NUMPIX);
    Serial.begin(9600);
    Serial.println("startup");
    delay(5000);
    // ----------- main application loop
    void loop() {
    // DEBUGGING FADE / RAINBOW LOOP
    PIXARR_toWhite();
    initPIXARR_null();
    PIXARR_toWhite();
    scdisplay_rainbow(1600);
    initPIXARR_null();
    PIXARR_toWhite();
    initPIXARR_null();
    PIXARR_toWhite();
    initPIXARR_null();
    PIXARR_toWhite();
    initPIXARR_null();
    scdisplay_PIXVector_snake(8 , 8 , 800); // loop multiples of NUMPIX for smooth animation
    scdisplay_PIXVector_snake(4 , 12 , 400); // loop multiples of NUMPIX for smooth animation
    scdisplay_PIXVector_snake(2 , 25 , 400); // loop multiples of NUMPIX for smooth animation
    scdisplay_PopInFadeOut(1000);
    incrPIXARR_looper(10);
    decrPIXARR_looper(50);
    initPIXARR_sparse(10);
    incrPIXARR_looper(50);
    decrPIXARR_looper(100);
    initPIXARR_sparse(5);
    incrPIXARR_looper(75);
    initPIXARR_rand();
    incrPIXARR_looper(150);
    initPIXARR_snakes(2, 10);
    initPIXARR_snakes(4, 5);
    PIXARR_toWhite();
    Dayton, OH
    50
    Default Re: Mega 2560 code Help Please!
    Nothing jumps out at me. What happens if you set the number of pixels to say 254 or 256? When you verify the sketch, how much memory is used? You may want to insert some Serial.println() statements in your loop to see where exactly it hangs up.
    lights, blow molds, and cut outs; no blinky-flashy yet
    3,489
    there are some 'int' and 'uint8' definitions being used to drive loops. an 8 bit integer will not work beyond 255 pixels. on an 8 bit cpu an int is 8 bits. the uint8's on the intensity settings are fine.
    Nov 2009
    Morrisburg, On, Canada
    2,540
    there are some 'int' and 'uint8' definitions being used to drive loops. an 8 bit integer will not work beyond 255 pixels...
    I'm not sure how this affects the routines but I discovered that if I use NUMPIX=250 it keeps going indefinitely, seeming to be normal. I only had a 50-pixel string for testing. But if I used NUMPIX = 256 then it will freeze after about 2 min into the void loop() with no further output from the MEGA board until a RESET. With NUMPIX = 252 it also will keep going indefinitely but near the end it freezes for a couple of seconds and the void loop() appears to repeat again with a couple of sec of freeze at the end (or near it - not sure).
    3,489
    that is because those variables I mentioned are loop indexes. When you finally hit one of those loops they will never terminate because the index will never increment enough to equal max pixels (they restart at zero when they hit 256)
    Oct 2018
    5
    Is there anyway this can be converted or modified to drive 349 pixels? Like I said, I am a newbie and would appreciate the help. If not, I'll just run my Fast LED Demo for this year until I get educated to write my own stuff for next Christmas. By the way, I did change to 250 pixels and the program worked fine, but only for 250 pixels.
    Thanks for all the help!!!
    Dayton, OH
    50
    Lines like the one below are the problem. Around lines 136 and 143
    change them to
    for (int16_t i = 0; i < NUMPIX; i++) {
  8. Thanks Wildbill72 thanked for this post
  9. #8
    Nov 2009
    2,540
    that is because those variables I mentioned are loop indexes....
    Thanks Martin for that kernel of insight I missed. It makes perfect sense when one looks at the FOR loop where NUMPIX variable is used with an int variable. DUH ....
    I changed those int's to int16_t where the FOR loop uses the NUMPIX variable and now the program doesn't freeze. I think that was the problem with the code. Someone pushed the original code passed it inherent limits. With NUMPIX = 400 it still doesn't freeze and seems to work just fine.
  10. Thanks Wildbill72 thanked for this post
  11. #9
    Oct 2018
    5
    YOU GUYS ROCK! Thanks for the help! I made the changes and things work fine.
    Merry Christmas!
