Results 1 to 10 of 30
Thread: Which Pixel style for house outline?
    59
    Default Which Pixel style for house outline?
    I have about 325 linear feet of C9 LED's around the perimeter of my house that I would like to change to pixels for next year (my pixel tree was a HUGE success this year and my wife requested pixels on the house).
    Should I switch to a "Pixelbulb", Pixel strips, Pixel nodes, or pixel bullets for reliability, ease of install, and brightness.
    Would like to order before the end of the year to be able to prep the show for next year...
    Thanks so much
    Allen
    Colorado Springs
    3,668
    Default Re: Which Pixel style for house outline?
    It's totally up to you to achieve the look you want. If you like the look of the C-9's, then go with a style of Pixabulbs. If you don't really care about the daytime look, then Pixel Nodes work very well also. Your Pixel spacing will be determined by how far your home is from the street. The further away, the wider spacing you can use. Stay away from strips, repairs are much harder than with bulbs (or nodes). As far as ordering, you can usually save a lot if you wait for the Pre-Sales that should be starting pretty soon.
  3. Thanks arange98 thanked for this post
  4. #3
    Nov 2010
    Manhattan Kansas
    236
    I like the Pixabulbs since they look similar to C9s. This is my second year using them and i really loked how quick they went up using the Boscoyo pixatrim.
  5. Thanks arange98 thanked for this post
  6. #4
    59
    I never thought about repairs, so your comment about strips makes a lot of sense.
    When using nodes do you have to angle them down towards the street or just leave them facing upwards?
    Thanks!
  7. #5
    59
    Quote Originally Posted by K-State Fan View Post
    I have some pixabulbs but didn't find them to be as bright as bullets. Did you have the same experience?
    My LED C9s are minleon's and are very bright, so I want something as bright or close if possible...
    Thanks!
  8. #6
    Aug 2018
    9
    Following. Id like todo the same.
  9. #7
    Sep 2014
    Siler City, NC
    93
    About the strips... yes, stay away. They have their place I suppose, but a royal PITA when you have to fix a section (and THEN make it waterproof again).
  10. #8
    Mar 2015
    112
    I bought C9s from Ray Wu and have them all mounted to PVC for easier setup. The first couple of years I bought them that looked like traditional C9s with the base, but I've since switched to the flat base and put 2 zip ties on each side. I run them at 100%, whereas the other pixels I use in props are at 40% and I feel that works well for my show.
  11. Thanks arange98 thanked for this post
    Likes Stormyblade, rtificial liked this post
  12. #9
    Nov 2014
    Close to Hillsboro, OR
    393
    Quote Originally Posted by studiopro View Post
    Good to know. I used the GECE lights I've been using for years, only this time connected to a E682, and I just don't like how they look compared to WS2811 lights. Don't get me wrong - they look fine, but the dimming steps and colors just aren't the same. I've already got the go-ahead from the Head Finance Officer (aka wife) to change them out to Pixabulbs for next year. My plan is to ask Ray for 4" spacing with square/flat base and simply zip-tie them to 1/2" PVC as I did with the GECE bulbs.
  13. #10
    Nov 2010
    Manhattan Kansas
    236
    Quote Originally Posted by arange98 View Post
    Thanks!
    I had CDI C9s prior to the pixabulbs I am sure they are not as those were.
