Thread: Ws2811 Flood Light Problem
    Oct 2016
    1
    Default Ws2811 Flood Light Problem
    I recently purchased these floodlights. http://www.holidaycoro.com/10-Watt-R...ight-p/169.htm
    Im not sure what I am doing wrong but when I wire the lights up directly to my F16V2 it only displays a solid Blue dim LED. What am I doing wrong?
    Sep 2018
    25
    Default Re: Ws2811 Flood Light Problem
    are you sure the wiring is ok? Are you using the right pigtails?
    Viera, Florida
    136
    I recently purchased the same lights and haven't had a problem with them. As asked above, did you purchased the connectors/pigtails from holidaycoro as well? If not, then you need to take a look at the pigtail wiring. They may cross where you aren't expecting it too. Stupid question, but you are connecting to the input side of the floodlight correct? For mine, it was the male connector side and had the warning label sticker wrapped around it.
