Results 1 to 4 of 4
Thread: Will HLS run on A raspberry pi 3?
    Whitehorse, Yukon, Canada
    19
    Default Will HLS run on A raspberry pi 3?
    Wondering if HLS will run on a Raspberry PI3 ?
    Apr 2017
    39
    Default Re: Will HLS run on A raspberry pi 3?
    Iím not too familiar with HLS, but I believe there is no ARM based version. You can, however, use FPP to play sequences.
    Mar 2008
    1,599
    Quote Originally Posted by Yukoner View Post
    Well....technically no..... BUT when you export your light 'data' HLS creates an .hlsIdata file and saves in the the ExportIFiles folder.... You can use Xlights/Nutcracker to convert that hlsIdata file to an .fseq file which the Pi uses to run the sequence. Works great.
    19
    Thank You Santacarl this should work then, I like HLS for the easy to use programing, and did not want to switch programs,
    I am looking for something to run program on that would be easy to hide outside with the lights and I think the PI might fit the bill
