Results 1 to 5 of 5
Thread: Static Gradient across element
    Wheeling, IL
    84
    Default Static Gradient across element
    Is there a way to make a static gradient effect across a pixel panel? I have the Garlands effect "piling" up the panel but once its full, I want the gradient to stay.
    [B][SIZE=3]2013 - First year[/SIZE][/B]
    ~2,500 Lights, 8 mini-trees (1 RenardSS24, 22 Channels) Using Vixen 3.0.10
    [B][SIZE=3]2014 Goals/Additions:[/SIZE][/B]
    10' spiral tree controlled with 2 RenardSS24 (16 strands, 3 colors on each strand)
    Learn/play with RBG Pixels (potential RBG star for spiral tree)
    Learn/play with wireless/pixels to use with my other hobby, theatre.
    7,955
    Default Re: Static Gradient across element
    That sounds like something a simple pulse can do. Or is there something I'm not understanding in what you're trying to accomplish?
    Wheeling, IL
    84
    I want the bottom to be red and gradient to green at the top across the string of pixels (running vertically). Not a gradient over time.
    After messing around some more, I was able to make it happen with a Border effect with a very wide width.
    Maryville, Illinois
    1,712
    You can also us the Wipe. Set the Wipe On and Wipe Off options both. Set your gradient and then choose Gradient Across Items. Then up/right/up/down will change the orientation of the gradient.
  5. Thanks SetMonkey13 thanked for this post
  6. #5
    Jul 2019
    United Kingdom
    31
    Thank you Jeff! Even though this post dates back a while, I was about to ask the same question! Works like a charm.
