Results 11 to 20 of 23
Thread: What are you doing with wall wart plugs?
    Jan 2010
    Mims, Fl
    788
    Default Re: What are you doing with wall wart plugs?
    Any more input on this? Anyone else have preference to share?
    Chambersburg, PA
    722
    I've been told to try to keep the FM Transmitter away from most other electronics to prevent noise issues. If you have the time I highly recommend you watch this xEsssentials Video This talks about setting up and optimizing your audio.
    2016 - No Display
    Folsom, CA, USA
    2,113
    The best thing you can do for your FM Transmitter is to use a clean power source, and clean source for all your other devices in close proximity.
    In Lights Therapy
    Chambersburg, PA
    722
    Can you define a "clean power source" for us less technically savvy?
    2016 - No Display
    Folsom, CA, USA
    2,113
    I donít have test equipment so I use my FM antenna. Power up FM and tune in a radio at moderately high volume. Move your PS to the antenna and listen for noise....no noise is clean. If you have noise, change the PS. I donít use wall warts anymore. PS....a white box PS my best. Didnít need to spend big bucks.
    In Lights Therapy
    Chambersburg, PA
    722
    I don’t have test equipment so I use my FM antenna. Power up FM and tune in a radio at moderately high volume. Move your PS to the antenna and listen for noise....no noise is clean. If you have noise, change the PS. I don’t use wall warts anymore. PS....a white box PS my best. Didn’t need to spend big bucks.
    Thank You!
    2016 - No Display
    Jan 2010
    Mims, Fl
    788
    so it sounds like the PS is better than a wall wart. Is this a white box PS?
    https://www.amazon.com/MEAN-WELL-RT-...ateway&sr=8-36
    Sounding like 2 votes to keep the transmitter in a separate box.
    Jan 2010
    Mims, Fl
    788
    I will watch it for sure. I have been getting signal a couple houses each way from our home. My neighbors aren't close either.
    Folsom, CA, USA
    2,113
    Quote Originally Posted by ben&bobbi View Post
    White Box means a generic - that Mean Well you point to should be as good or better.
    However, not sure that model is right for your intended loads. You need to relook at the load of each intended device then add some more for protection. Size transformer on the results
    The Pi has a 2-3 amp requirement, I would use 4A-5A in the 5V column
    WiFi router = ??A's in 5V or 24V column
    Switch = ??A in 5V or 12V column
    FM = ??A in 5 of 12V column.
    I have PS's mounted in and/or next to BeagleBone, and ESP's with any issues.
    FM is on same backboard, about a 9" away from the PS and Filter......Oh, you could add a filter to your FM PS. I used http://renard-shop.com/other-boards/...mer-board.html
    PS: Mean well makes a 5V/12V unit, no 24V RD-65 or bigger one RD-85. I think I would do 2 transformers, one for each voltage.
    In Lights Therapy
    Jan 2010
    Mims, Fl
    788
    mrGrumpy,
    Thanks for the detailed response. i really overlooked the amperage needed - you are right. I thought i had the voltage covered, and assumed the rest would fall into place. Much more informed now.
    Can i use a 12v supply and one of these for the Pi? Is there a better buck?
    https://www.amazon.com/gp/product/B0...=APHB2NWNKDSBL
    Last edited by ben&bobbi; 09-09-2019 at 12:06 PM. Reason: corrected wattage to voltage
