Results 1 to 10 of 14
Thread: Multiple sequences open
    Plant city, Florida
    87
    Default Multiple sequences open
    I cannot open multiple sequences at the same time. Has this feature been removed?
    I was trying to copy my tune to sign effect to each sequence.
    Sent from my SM-G950U using Tapatalk
    3,900
    Default Re: Multiple sequences open
    Which version are you running? I downloaded just before Halloween and that version allowed me to copy just fine between sequences.
    7,856
    No, that still works fine. I just opened a handful of sequence editors on the current version and they all work.
    Plant city, Florida
    87
    I'm using build 3.5 build764
    When I open the second sequence the window opens but the sequence won't load until I close the first sequence.
    Maryville, Illinois
    1,662
    I just tried this with the same build and it works fine for me. Are there any logs in the My Documents\Vixen 3\logs folder?
    Plant city, Florida
    87
    There are no logs of this happening.
    Plant city, Florida
    87
    in the picture above the bottom sequence is the first to load.
    the top sequence is the second to load, but it stops loading, it will finish loading when i close the first one (bottom).
    Plant city, Florida
    87
    Problem solved. almost
    Apparently it takes over 2 minutes for the second sequence to load and then render.
    Last year the second sequence would load much faster.
    I'm not sure why the long delay
    computer specs:
    Intel Core i5 560M @ 2.67GHz
    8.00GB Dual-Channel DDR3 @ 532MHz
    223GB SSD
    7,856
    Load time is a function of sequence complexity vs system resources. Are you using the 64 bit version? the 32 bit version would likely run out of memory in that scenario. 8GB of RAM is a bit on the low end for doing multiple complex sequences. More ram might help. Are you doing this with your output controllers enabled? disabling them while you do this copy operation would free up more resources for the second editor.
    Plant city, Florida
    87
    I am using 64 bit.
    8 GB ram maxed
    controllers are disabled.
    Is it time for a computer upgrade?
