Results 1 to 7 of 7
Thread: Cause of this?
    Nov 2017
    Michigan
    64
    Default Cause of this?
    Half my arches wont respond to me changing the color. They stay a white or yellow color. I know on my other side I just got to play with the channel count to get rid of the little bit of green on there. Any thoughts
    Sent from my SM-G950U using Tapatalk
    Williamsburg, VA
    917
    Default Re: Cause of this?
    what controller are you using, and what firmware? I've ran into this on my E682 running V5 firmware. changing the resistor values and power injection fixed it.
    are all of them on the same output?
    do you have power injection?
    Nov 2017
    Michigan
    64
    Im running a F16v3 with a FPP
    Williamsburg, VA
    917
    in order for someone to help, you need to provide more information , screen shots of your setup.
    Dec 2017
    Phx,AZ
    131
    I get this with fpp on my pi, when I don't load the correct or more then the correct pixel count in the player compared to the sequence. So in turn the player does not play those pixels and they just stay on. Play with fpp and pixel count your using. Reboot and then test sequence till they play correctly or go out. Does that make sense?
    Nov 2017
    Michigan
    64
    Quote Originally Posted by mister softee View Post
    Yes, it does. thanks
    Anchorage, AK
    300
    The green may be caused by using 510 ch universes and the falcon is set to 512. I just use 512 even though it splits a pixel at the universe mark. 512ch/3= 170 pixels + 2ch. Just continue on the next universe.
