Results 1 to 9 of 9
Thread: Distro boards or power blocks?
    Dec 2015
    Saint Louis
    173
    Default Distro boards or power blocks?
    Hi everyone,
    This is my first year with pixels, and I have a question.
    Is there an advantage to using one of these over the other one?
    https://www.amazon.com/6-Way-Fuse-Bl...se+block&psc=1
    https://www.pixelcontroller.com/stor...roller=product
    2016 - Static Light Show
    2017 - 72 Renard Channels - Roughly 4,200 Lights - 3 Sequenced Songs
    2018 - Added Pixels to Rooflines
    Website: www.doyonlights.com
    You Tube: https://www.youtube.com/channel/UCQ8...yLJieEEwDto7xg
    Adding Pixel Arches, Snowflakes, and Singing Bulbs in 2019!
    Folsom, CA, USA
    1,955
    Default Re: Distro boards or power blocks?
    Both do the same
    F8-Distro is easier to get to connections and work the connection. 8 ports. Best for setup and takedown. Need to provide a mount. Not always in stock.
    Fuse Block - more compact, only 6 ports. likely always available.
    My first choice would be the F8 when in stock.
    In Lights Therapy
    Columbus, OH
    4,263
    Another option is the Pops Power Distribution Board.
    It's the only distribution board I know of that has been load tested with professional equipment.
    https://holiday.lighting/
    http://www.doityourselfchristmas.com...with_4_Outputs
  4. Likes dcamron liked this post
  5. #4
    Nov 2013
    Morganton,North Carolina
    1,646
    I use these with my Falcon build.Work great!
    (1)Falcon F16V3
    (1)Renard SS16
    (1)Renard SS24
    (1)EDM-LCD-CS-EP
    (20)P10 Panels
    WIKI
    Become A Supporting Member
    Falcon Christmas
    Renard Controllers
  6. #5
    Chambersburg, PA
    698
    The advantage as I see it to a Power Distro board is that you are giving yourself your V+ and V- in the same location. If you use the Fuse Block for the V+, you need somewhere to combine and distribute the V- side of the circuit lke This Grounding Bar. I started with the Fuse Block and Grounding bar, but in my newer enclosures, I have moved to the Power Distribution Boards for the convenience of the design. In addition to the other Distro Boards listed in this thread, i like the RenardPlus DC Distro Board, it has resettable Poly fuses, while it does not have some of the power ratings of other designs, for my small enclosure system, they work great.
    2016 - No Display
  7. Likes ezellner liked this post
  8. #6
    West Bloomfield, MI
    651
    As others have said, distro boards are my preferred way to go as well. Built in fusing, neat arrangement, similar to controller connections, etc. I use these: https://www.crockettfantasyoflights....cfol-distro-8/ They have LEDs that indicate a fuse is blown which is handy when you're out in the cold and dark.
    Ed
    Happily retired
  9. #7
    Jan 2019
    Dallas, TX
    7
    Just got several of the Falcon F8-Distro boards and wondering if people are putting fuses between the power supply and the distro board? If so,what size fuse would be appropriate for a 5v power supply?
  10. #8
    1,419
    Quote Originally Posted by sfuzzy View Post
    Well the 8 outputs have 5A fuses so that would be 40A, but the power input for the board is only rated for 30A, and if you use the 80% rule for safety, then you are down to 24A on the input line, (3A per Output average)
  11. #9
    Dec 2017
    Phx,AZ
    131
    I use crocket fantasy 4 lug distro boards. On everything. They even sell a dual 4 boards for 2 pwr supplys, great on matrix screens. They also Have led indicators,fuses and are a fairly small size as well as. I rarely use 8 boards, unless it's on a bunch of low pixel props off 1 or 2 ports.
