Results 11 to 18 of 18
Thread: FPP to RPi3 to Arduino Uno and Mega to Custom SSR's
    Hicksville, New York
    48
    Default Re: FPP to RPi3 to Arduino Uno and Mega to Custom SSR's
    Make sure you are using a powered usb hub. The PI cannot provide power for a large number of devices connectedt to the usb ports.
    I am only using 2 arduinos so for now do I really need the hub? Is 2 arduinos a lot? I don't think I will be expanding more than 2 arduinos anyyy time soon.
    3,048
    Quote Originally Posted by Spankyty View Post
    as long as you are not powering the arduino devices via the usb port, you will be fine
    48
    Here's my diagram. It's just not letting me dim...
    975
    what sketch did you implement to dim?
    48
    Well, to test the dimming, I was using this:
    Code:
    unsigned char AC_LOAD = 9;    // Output to Opto Triac pin
    unsigned char dimming = 3;  // Dimming level (0-100)
    unsigned char i;
    void setup() {
      // put your setup code here, to run once:
      pinMode(AC_LOAD, OUTPUT);// Set AC Load pin as output
      attachInterrupt(2, zero_crosss_int, RISING);
      // Serial.begin(9600);
    void zero_crosss_int()  // function to be fired at the zero crossing to dim the light
      // Firing angle calculation : 1 full 50Hz wave =1/50=20ms
      // Every zerocrossing : (50Hz)-> 10ms (1/2 Cycle) For 60Hz (1/2 Cycle) => 8.33ms
      // 10ms=10000us
      int dimtime = (100*dimming);    // For 60Hz =>65
      delayMicroseconds(dimtime);    // Off cycle
      digitalWrite(AC_LOAD, HIGH);   // triac firing
      delayMicroseconds(8.33);         // triac On propogation delay (for 60Hz use 8.33)
      digitalWrite(AC_LOAD, LOW);    // triac Off
    void loop() {
              for (i=5;i<85;i++)
                dimming=i;
                delay(20);
              for (i=85;i>5;i--)
                dimming=i;
                delay(20);
    Once I get the dimming to work, I'm going to run into the next step of problems. Getting the code for arduinos to output the sequences.
    Southern California
    725
    I am a bit confused. You said in post #1 that you had completed your show and everything works beautifully. But now you just want to go wireless.
    But post #15 you said that you only have a test code.
    Do you have a working system when you use your standard computer instead of RPi ??
    Why are you using an UNO for 6 outputs? Because of PWM pins? With a Zero Cross detector and ZParticle's sketch, you can run at least 32 outputs from one MEGA with dimming.
    Kevin
    48
    It worked without a zero cross detector on the computer. Then I put a ZCD in, and nothing fades. I also thought you needed pwm for dimming. So thanks for letting me know that. I can cut down on one Arduino. I don't know why it doesn't dim, I think it's my code. Not sure.
    EDIT: I got it back to normal where it triggers on/off but the fading still does not work.
    Schematic_Solid-State-Relay_SSR-SchematicV2_20181110124939.pngSchematic_Zero-Cross-Detection_Sheet-1_20181110124556.png
    Last edited by Spankyty; 11-10-2018 at 11:45 PM. Reason: added zcd schematic and ssr board schematic
    Southern California
    725
    Yeah, could be your sketch. Or it could be your SSR. You can try another sketch that is known to DIM, by ZParrticle.
    Kevin
