Results 1 to 6 of 6
Thread: COnfused
    Nov 2017
    Michigan
    59
    Default COnfused
    So I set up part of my display tonight, arches with strips to be specfic. When I plug it all in. ONe of the arches light up white. So i figure I had a problem. THe onther arch was off. I pulled it inside, Plugged them in to my controller and they each light up, but different color pattern from the other one. I figured i got a wire problem some were. ANy advice before I strip it all down.
    Folsom, CA, USA
    1,639
    Default Re: COnfused
    Wrong start channel is often the problem. Channel count, 510/512 boundary....rarely wiring issue.
    In Lights Therapy
    Nov 2017
    Michigan
    59
    How would I fix this? Im using just a cheap controller to test them.
    Folsom, CA, USA
    1,639
    What controller and what sequencer
    In Lights Therapy
    Nov 2017
    Michigan
    59
    Just a simple controller for ebay. Four buttons for mode speed and something else. Nothing special i cant select channels
    975
    Did you not have a controller hooked up when you powered them up? All white is a "feature" of some strips when no data signal is received.
    According to some people who have experienced this problem, it meant that the first pixel was fried.
    Yet another possibility is the voltage is "wrong" for the strip. Some like it it right on spec, some like it higher, many like it just a bit lower.
