Thread: Issue with Output in HLS
    Jul 2014
    Indiana
    33
    Default Issue with Output in HLS
    I have been running my show off of an OLD XP machine for the past 3 years. I copied all of my files over to a windows 7 machine and all is working as I would expect except for the output. I cannot get my show to output to my controller. I am getting an error "unable to transmit the sequence-outputs are not properly configured". I have verified COM port, prepared channel for output, etc. I am sure there is something simple I a missing. Any thoughts? Thanks for any help!
    6,072
    Default Re: Issue with Output in HLS
    After you have setup your com port then entered the
    Select output method and compile for show .
    Check that you have set transport and protocol , also put a check in the active box .
    when all is good status will be green . Red status will indicate issues .
    You did not mention if you are using e1.31 or ethernet , if so you will need to select your Nic also prior to entering selecti output methods .
    Jul 2014
    Indiana
    33
    Thank you for your reply. So, I think you have me in the right direction for sure. I am using e1.31. I select "select output method and compile for show" set transport to COM, Select the correct com port, but then, I cannot select "Active" and it does not save. (I also select Renard) Status remains red.
    Jul 2014
    Indiana
    33
    GOT IT! Had to "prepare channel for output and then follow the steps you laid out. Cant thank you enough!
    6,072
    The output tab is laid out for use in a procedural fashion for successful output .
    I figured from your first post that you had the output steps roughly , so I just started where you left off .
    Sorry I should have replied with all the steps required for certain output .
    Happy to hear you got it !
