Results 1 to 10 of 16
Thread: Renard Plus TR-24 PIC programming problems
    Sep 2007
    Valley Center, Ks
    295
    Default Renard Plus TR-24 PIC programming problems
    I have never programmed a PIC18F4520 before. I keep getting “Target device was not found (could not detect target voltage VDD). You must connect target device to PICkit 3”. I have used this setup before with PIC16F1825 chips. I changed the jumpers per the board. See pics below. Any ideas?
    Dave
    128 Olsen 595 Vixen controlled channels
    about 30,000 lights
    Winter Haven Florida
    2,843
    Default Re: Renard Plus TR-24 PIC programming problems
    you could program the chip right in the board
    James WinterHaven Fl
  3. Likes Ruppro liked this post
  4. #3
    2,843
    J2 J3 J4 J5 J6 J7 is that set on 1/2 or 2/3 should all be 2/3
  5. Likes Ruppro liked this post
  6. #4
    Sep 2007
    Valley Center, Ks
    295
    Not sure. The adapter isn’t labeled. They were all the other direction for the PiC16F1825. So I moved them for this since it said 2-3
    Dave
    about 30,000 lights
  7. #5
    2,843
    I am not sure since this has no listing for that chip that is why I suggest putting it back in board and doing it that way
  8. #6
    2,843
    click to enlarge image
  9. #7
    Sep 2007
    Valley Center, Ks
    295
    So I just connect the PICkit 3 onto the program header. Where did you get that picture? From the assembly doc?
    Dave
    about 30,000 lights
  10. #8
    2,843
    yeah it is off the renard plus site
  11. #9
    Aug 2013
    Greer, SC
    73
    I have flash all 12 of my tr24 on the board itself.
    DO NOT PLUGIN THE BOARD TO POWER
    THE BOARD IS POWERED THRU THE CABLE, and should not be powered through the board
    [2017] 32 Renard Channels, 3360 LED Lights
    [2018] 240 Renard Channels, 14070 LED Lights, 2 projectors, and one donkey
  12. #10
    Sep 2007
    Valley Center, Ks
    295
    Tried on the board this morning before work. No dice. Same error message.
    Dave
    about 30,000 lights
