Results 1 to 10 of 10
Thread: 3.5u4 is now available
    Maryville, Illinois
    1,720
    Default 3.5u4 is now available
    3.5u4 has been released. This has mostly smaller bug fixes and a few improvements.
    Release Notes - Vixen 3 - 3.5u4 Release Build
    ** Improvement
    * [VIX-2177] - Text positioning control direction backwards in the Text effect.
    * [VIX-2500] - Custom Prop Editor workflow improvements - improve starting name and file location handling
    * [VIX-2539] - Add ability to add positioning to images in matrix lipsync effect
    * [VIX-2609] - Play LipSync phrase/word by double clicking the mark
    * [VIX-2613] - Add a color change layer mixing filter
    * [VIX-2614] - Meteors doesn't work properly for linear display
    ** Bug
    * [VIX-2610] - The Random and Rainbow options only show red colors in Pinwheel effect.
    * [VIX-2611] - Gradient across items in Wipe effect not working correctly.
    * [VIX-2612] - The Mask and Fill setup window does not properly initialize the current state of the requires mixing partner checkbox.
    * [VIX-2616] - Vixen crashes on Papagayo import when file is incomplete
  2. Thanks Kev7274, mildog thanked for this post
    Likes outbreak liked this post
  3. #2
    Mar 2014
    375
    Default Re: 3.5u4 is now available
    There is also two new videos on the Vixen Lights Software YouTube channel that show some of the improvements and fixes.
  4. Likes outbreak liked this post
  5. #3
    West Bloomfield, MI
    676
    Quote Originally Posted by Gnarmstr View Post
    Thanks for making the videos. They are a great help in understanding the changes.
    Ed
    Happily retired
  6. #4
    May 2010
    ottawa , ontario, Canada
    1,752
    good work as usual any idea IF and When the copy paste in the lipsing wording/ phrase will be add ?
    thanks
  7. Thanks tecnageek thanked for this post
    Likes tecnageek liked this post
  8. #5
    Evansville, IN
    342
    I just received the following message via popup. "an unexpected error occurred while drawing the grid. Please notify the vixen team and provide the error logs." Can you advise how to go about this and specifically which log files you will need? This is on 3.5u4 build 759.
  9. #6
    7,961
    go to http://bugs.vixenlights.com and start a new issue ticket.
    You can attach the four application log files to the ticket. error and fatal are most important. You can skip the scheduler log.
  10. #7
    Evansville, IN
    342
    Done, thank you. If there is anything else I can do to help please let me know.
  11. #8
    Washington State
    180
    Quote Originally Posted by barbotte View Post
    thanks
    I second this.
    No pressure. Just want to let you know it is a very much wanted feature.
  12. #9
    Maryville, Illinois
    1,720
    Quote Originally Posted by tecnageek View Post
    I second this.
    I hope to work on it in the coming month. I am heads down trying to get my display going, so anything but a critical bug has been on the back burner. Once I get that lined out, then Iwill have more time to focus on items like that again.
  13. #10
    Washington State
    180
    Completely understand, It's crunch time.
