Results 1 to 4 of 4
Thread: after update problem
    Jan 2018
    Dordrecht Nederland
    25
    Default after update problem
    hi to all
    after the update to 3.5 problems started here.
    meby some one can help
    building a lichtshow with 3 arduinos 2 set for pixel that was working and one for relay outputs.
    After soms problems with contacts with arduino made a pcb for solid constrution.
    that was working nice .
    after update the working of the relays is very wrong.
    even when i put back versie 3,4 this stays the same .
    the relays are switching random also when there is no comando to do so.
    take the arduino and a relay bord to a diverent laptop and there is working on version 3.3
    running vixen 3.5 update
    arduino mega
    and 6 relay bords
    running W10 64 bits
    script what is running is the script that DEE is using
    only he using 48 channels and i use 53
    anyone this problem also
    thanks and greating from the Netherlands
    henk
    Jan 2018
    Dordrecht Nederland
    25
    Default Re: after update problem
    hi
    after a day of trying noting works anymore.
    3.2 3.4 3.5 3 x install nothing works .
    it looks that vixen is not get data from the arduino,not posible tot set a efect stays dark.
    the 32 and 64 version same problem.
    when vixen starts 3 leds on the arduino are on ,after setting the header the relays starts random to work
    looks somting is wrong on the computer
    hoop some one a idee what to try
    ill be happy
    thanks
    1,809
    Are you using USB serial? or a real serial port? or USB to 485?
    Have you checked the baud rate both in Vixen and on your arduino?
    Are you using "header" code in the sketch? Have you set the same in Vixen?
    Jan 2018
    Dordrecht Nederland
    25
    thanks for your idee mike
    after reloaded vixen en the script looks that it is working
    have reconect usb servel times al that was correct
    wat i think is that er somting whas bloked in the laptop.
    because the problem stays with old en new versions of vixen .
    only reboot whas not good the usb need to be disconected also .
    when i use a header the relays start a random chase
    but so far it is working after 30 x instal lol
    thanks for your help
    and goodluck with the hobby
    henk
