Results 1 to 6 of 6
Thread: 3D Bubble Tree
    Jun 2007
    White, GA
    66
    Default 3D Bubble Tree
    This year I wanted to combine some ideas I had found on here and use some frames I purchased a few years ago at one of the Christmas Expos. After setting up large displays for years, this year I am working on a smaller, portable display that I can setup easily, but cram as much as I can into a small package. I took ideas from the Bubble Tree mentioned here and wanted to do a 3d version. I am finally getting something worth looking at and wanted to share.
    I started by cutting tons of different sized PVC pipe into short sections.
    Then I used PVC glue to attach them to corrugated plastic sheets pre-cut to my frame panels.
    Then I center-drilled the backing in each PVC cutout, inserted the pixels, cut to length, and soldered the connectors so each panel can be cascaded. I wrapped each panel in white shrink-wrap which helps protect it, hold it all together, and diffuse the light.
    Here are a few more pics. I should have the finished project by this weekend, but wanted to get some pics up. A lot of thought and experimenting went into this project. With the shrink wrap, it is coming together better than I expected. In addition to this centerpiece tree, I have 16 smaller wire-frame tree elements that will form the display. Let me know your thoughts and I hope you enjoy.
    Joey
  2. Likes uncledan liked this post
  3. #2
    Jun 2007
    White, GA
    66
    Default Re: 3D Bubble Tree
    Joey
  4. #3
    189
    Very nice--love it when people come up with new ideas and implement them well!
  5. Likes joeberg liked this post
  6. #4
    Jun 2007
    White, GA
    66
    Joey
  7. Likes Keith R liked this post
  8. #5
    Chambersburg, PA
    593
    Add a PixelStick and a JDeation DIY enclosure, all you need is a power cord to place this anywhere in your display!
    2016 - No Display
  9. #6
    Mar 2017
    Indiana
    98
    This looks great! Very clean looking build too
    Halloween 2018 Lights: https://youtu.be/1FM4xhan_G4
    2018 Behind the Scenes: https://youtu.be/jGKUd9HzKGw
    Other shows and behind the scenes:
    https://www.youtube.com/channel/UCg1...c85-wgbnkNiLOw
