Results 11 to 20 of 21
Thread: New Windows
    Winter Haven Florida
    3,039
    Default Re: New Windows
    maybe try http://tinypic.com
    James WinterHaven Fl
    3,039
    ok that worked
    3,039
    ok I can say I lived in house had meatl siding and shutters I used zip ties and ran then around the shutter to give me place to hold my incandescent lights I ran zip tie through the slat at top and out and round and held the wire
    Oct 2018
    Wentzville, Missouri
    8
    everything is vinyl on the house so I don't believe zip ties will work.
    3,039
    you have slats in the shutters you run the zip ties through the slats and out around the shutter
    Oct 2018
    8
    I can give that a try, thanks for your help !!
    Nov 2014
    Destin, Fl
    157
    When I put pixels around our windows, I drilled holes into J-Channel from Home Depot. Then I use two x 1" pieces of velcro and stick the J-Channel to the brick! This stuff is great and maybe you can figure out a way to use it.
    https://www.homedepot.com/p/VELCRO-B...-USA/304727483
    Mar 2017
    Lancaster OH
    178
    I've had good luck with the command strips. I put some up last November and they are still there. The surface must be extremely clean ( should not be a problem with new windows). The only problems I had was when I tried to add a couple late November after the temps had dropped. They hold up in cold weather if applied in warm weather but don't like to stick when you apply them to an ice cold surface.
    Chambersburg, PA
    846
    I use a PVC Pipe Frame for my windows and have clips (painted to match) mounted on my shutters to hold the frames.
    2016 - No Display
    24
    Are the shutters the only support structure for the whole frame? Do you have any photos you could share? I find J channel 10x easier to drill than 1/2" PVC and I'm stuck in a similar situation where my windows are a white vinyl 1.25" edge (with the siding coming in behind that white edge). I'm really hesitant to drill into that white edge and I've wondered if the shutters can withstand the weight of a PVC frame. The more I think this through, the more I think J channel would work well because the longer side of the J could "rest against" the shutter's side, lay on the top edge, etc. The bay windows have no shutters so that'll complicate things for me for sure.
