Results 21 to 30 of 49
Thread: Are there any alternatives to pigtail cables for waterproof connections?
    Oct 2010
    NW Suburbs of Chicago
    145
    Default Re: Are there any alternatives to pigtail cables for waterproof connections?
    Quote Originally Posted by RGB_Mixer View Post
    Oh yeah - these are, IMHO, the best alternative for outdoor LOW VOLTAGE stuff. Much faster and a clean cable end - no hassles with having to add a cable to some of these MOLDED types. No tiny screws to loose!!
    Water resistant/proof - easy to handle. For most, the only drawback is having the right crimp tool. These crimpers are available ... 1.5mm un-insulated. Double crimp. The first few are a bit of a hassle until you get used to how they work. I think I have done thousands of these over the past 5 years.
    UPDATE: At first glance, I did not notice the ones ukewarrior listed had wires on them. I get the full kit of parts and build all my own.
    I have been using these for several years now with excellent results. You can put together any cable, any length and at any time.
    I found mine on eBay. As always, shop around for the best price and delivery times, especially if you need them yesterday. These make adding power injection a breeze!
    Attachment 40696
    The contacts are rated for 10 amps continuous.
    Only other suggestion is to make sure the boot over the wire is sealed. I have some "TEST" cables I sealed with hot glue ... 26ga does not fit well and needed some HELP. My experience is 12-20 gauge wire, depending on the thickness of the insulation.
    I have not had any failures to date. Anything over 10A I use the Anderson Power Pole system.
    Good luck
    These are all I will ever use , I have a few round pigtails for the 5v stuff and I hate them, too many differences between manufacturers. And the best part of these is free next day shipping from Amazon. I will never use round pigtails again
    4,056
    That is the spray version. I use the oil. Less waste and it gets into the wire jackets (and anything else it touches). The stuff is great and it is insidious. Worth the trouble. Others use dielectric grease and claim to have good results. I never tried the grease so I cant say one way or another.
    Here is the oil: https://www.amazon.com/Corrosion-500...sion+x+gun+oil
    Aug 2012
    Nova Scotia, Canada
    1,694
    Do you re-apply every year?
    4,056
    every time I touch the connectors I put a drop on them. A drop goes a long way. To be honest, if it is really cold outside i will skip reapplying the oil. I have seen no difference between the skipped and not skipped connectors. But I try to do it every time.
    Jan 2011
    Warren, NJ
    1,741
    I bought the bigger bottle a few years ago and have not run out. https://www.amazon.com/gp/product/B0009GYRWW
    Since none of these connectors are gold plated, they all will corrode with moisture and current around them. The CorrosionX does a good job of cleaning the connectors off. I have used it on all of my DC connectors and pixels for the last 7 years and I have not had an issue yet. I don't trust the orings on the round connectors, and when they are cold it is hard to tighten them correctly. I flood the male end with the oil and seat each connection twice to get the oil into the female end.
    I also swear by Anderson Powerpole connectors for any connector 10A and over.
    2012
    12x REN SS24 AC Controllers
    4x REN48LSD DC Controllers
    4x E681 Pixel Controllers
    1x RPM E1.31 Protocol Bridge
    16x REN-W Rev6 Wireless
    EDM-LCD-RDS-P FM Radio Transmitter
    17' Hybrid Megatree, 48 channel (12each of Red, Blue, Green, White) + 12 Strings of 36 GECE Pixels Folded in half
    100' Pixel Guardrail (300 GECE)
    4x 10 Segment sleeved Leaping arches
    70x FAST Snowfall Tubes
    16x Double DIYC Floods
    4x TIR Commercial Floodlights
    8x Dancing Snowflakes
    9x Window Frames with 4 Channels each of C7 LED replacements
    30x Xenon Strobes
    All regular channels are CDI 100Ct LED strings
    Long Island, NY
    7,678
    Attachment 40696
    Good luck
    I have the 4 conductor round pigtails and hate them. I recently ordered 300 sets of the 4 pin square versions of these. As needed and to continue as the display comes down everything will be transfered over to the new connectors.
    Nov 2014
    26
    I also run exclusively JST connectors. They see to work fine, even leaving them buried in a snowbank. I like the suggestions of the anti-corrosion stuff, though. I noticed this year the connectors starting to get a little corrosion on the props I used last year.
    4,056
    I tend to misplace the bottle of CorrosionX so instead of getting one big bottle I bought three of the smaller bottles. None is less than half full and all of them have gone missing at one time or another
  9. Likes jklingert liked this post
  10. #29
    Northern California
    1,066
    Small question about terminology. My understanding is that in our context, a pigtail is the loose wires end, that you need to solder/crimp/screw to something else. So a cable could have some connector on each end (same or different), or it might have a connector on one end and loose wires on the other end - a "pigtail". In particular, some connectors are sold with a short cable ending in a pigtail, so you can splice the pigtails into some other cable or devices, rather than dealing with for example crimpling the connector conductors directly.
    A device may come with pigtails - like loose wires hanging out rather than some connector or pins or screw terminals. For example, some wall (AC mains) dimmers come with stranded pigtails rather than having screw or push-in terminations; instead they are installed using using wire nuts to connect the pigtails to the solid house wiring.
    Besides devices, one can buy JST connectors with pigtails, round connectors with pigtails, those waterproof linear connectors with pigtails, etc - if one is buying the given connectors with a short bit of pre-attached cable/wire to which one can solder/crimp/screw.
    If Ray sells "pigtails", that means he's actually selling connectors with pigtails on the other end. As it happens, he mostly sells round screw-together connectors in a pigtail version.
    Is that correct? Or am I confused?
  11. #30
    4,056
    yes a pigtail is pretty much any connector that you attach to something else.
