Results 1 to 9 of 9
Thread: Switch From Dipole to 1/4 Wave
    303
    Default Switch From Dipole to 1/4 Wave
    Thinking about making a new antenna this year. My current one works pretty well but I'm interested to see if I can get a better signal from a 1/4 wave. Before I buy the parts, does anyone have experience or an opinion?
    Jan 2014
    88
    Default Re: Switch From Dipole to 1/4 Wave
    I use this one, works great! I like it because I can mount it directly on a ground rod (bottom of the antenna is ground). https://www.jpole-antenna.com/shop/l...nnector=so-239
    My FM transmitter (FMT-212) has an "SMA" connector on it (miniature coax) so I got this cable: https://www.amazon.com/gp/product/B00ANX1JGI/
    Regards,
    Dennis the Menace
    Delaware, OH
    4,453
    I have always run a 1/4 wave and have been amazed at the performance.
    4,610
    Ran a dipole my first year. Very unhappy with it. Went to a 1/4 wave ground plane and never looked for anything else. Super easy to build (one connector, five pieces of wire) and twenty minutes to build (took longer to order the connector). Great range and perfectly clear. Since I used 14 awg wire for the legs and tip (left over from a room remodel) it cost me $3USD total to build the antenna. The antenna is flexible and collapses for storage. I hang it from a low tree branch and run a string from the legs to tent stakes to keep it stable.
    Nov 2010
    Charlotte NC
    646
    Can you send the reference to the build?
    3rd Year - 640 channels - 18,706 lights - 1 Lost Mind
    FACEBOOK: Fallatt's Charlotte Christmas
    Dallas TX
    671
    This thread is very timely for me. This is the great thing about forums. Someone somewhere is wondering the same things.
    I’ve been using a dipole the last few years and not satisfied with the performance. Had been thinking about going to 1/4 wave but just didn’t know if it would be any better. Reading this thread now I think I’ll make the change. Thanks!
    4,610
    This is the calculator:
    https://m0ukd.com/calculators/quarte...nna-calculator
    I used something like this to connect to my coax. You purchase one to go with the type of cable you are using.
    https://www.ebay.com/itm/UHF-female-...Tqg:rk:70:pf:0
  8. Thanks angus40 thanked for this post
  9. #8
    303
    For the station I plan to use, the monopole is 31.48 inches and the radials are 35.26 inches. That's a lot larger than I expected but does it sound about right? If it is then where are you mounting an antenna this big? My dipole is about 6 feet but it mounts easy because it's just a pole.
  10. #9
    4,610
    it sounds about right. Keep in mind a 30" leg at 45 degrees is only 15" high. Total height is about 50" I hang my antenna from a low hanging tree branch. The legs end about 5" from the ground. I get clear signal for about 1/2 mile. If I raise it up the distance goes up but that is not what I want. High quality at my house and a bit down the street is all I need.
