Thread: Gemmy Fire and Ice Spotlight
    Oct 2018
    2
    Default Gemmy Fire and Ice Spotlight
    Hello all. I am not sure if this is the place the place to post but I am going to give it a shot.
    I have a Gemmy Fire and Ice Purple/Orange spotlight. I have only been using it for a couple of weeks and noticed the other day that it appeared to not be working. Upon further inspection, the 3 LED lights inside were very dim but the rotating disc was still rotating. I unplugged it to bring it inside and attempt to fix it. When I did that, as residual power drained from it the LEDs flickered but at full brightness.
    After taking it apart and looking for an obvious broken connection I found nothing. Has anyone experienced and know how to fix this and/or have ideas on how to fix it?
    Sent from my SM-G950U using Tapatalk
    Sep 2018
    29
    Default Re: Gemmy Fire and Ice Spotlight
    Bad solder joint
    Oct 2018
    2
    Quote Originally Posted by jackfrost2 View Post
    Bad solder joint
    Everything looked good though. If I attached some photos would you possibly be able to pin point which one, you think, might be bad? Thanks
