Results 11 to 20 of 27
Thread: LOR controller in DMX.. Need your help..
    110
    Default Re: LOR controller in DMX.. Need your help..
    Thanks a ton for chiming in Jon. I have the boxes all addressed in LOR 1-9. I have Open DMX in V3 with 144 channels and the channels are all mapped correctly. I checked in graphical view and reconciled with my spreadsheet. The pairs are what is troubling. (3,4 / 7,8 / 11,12 / 15,16) Effectivly half of the unit. Its too symetrical and too repeatable... I am missing something, or there is a bug..
    When I move the ethernet from unit 1 to unit 3 and send the test sequence, skipping unit 1 and 2. The same (3,4 / 7,8 / 11,12 / 15,16) arent working.
    7,665
    What happens if you readdress the boxes so that #3 is #1, and #1 is #3. Does the problem follow whatever box is given ID #3, or does it stay with the same box?
    I don't have a testing rig here that could emulate your hardware configuration close enough to test for potential bugs.
    BTW, there's no Ethernet involved here. You have a DMX signal on an RJ45 connector.
    110
    OK GOOD call... So when I reassign that to 1, all light up. So.... what does that mean? When I address it as 3 it skips those 8 channels.
    Yes i know it is DMX, I was speaking more of the Ethernet as a physical cable rather than the communication.
    7,665
    Well, that means the controller hardware is fine.
    That pattern strikes me as too coincidental. Every other pair of channels, on only the 3rd controller.
    What are you using to test the outputs? Are you using just something like a set level on those particular channels?
  5. Likes TazChaLet liked this post
  6. #15
    110
    Yes Set level. I'll try Pulse at 100%
  7. #16
    7,665
    What’s the color configuration on those elements? Are you using an effect with the right color for that element?
  8. #17
    110
    Yea so these are White and Blue on a megatree. I tried Pulse, 100% with the right colors. I tried all the configs. all dont work on the pairs. I agree with the pattern.
  9. #18
    110
    These are the channels that are in question
  10. #19
    7,665
    While I'm pretty sure it's not related to your problem, That's not really the right way to go about defining RGBW elements in Vixen. You should only have one element that encompasses all 4 colors. You'd then define the color handling as multiple independent colors, with the RGBW type. Then when they get patched, you'll see the color breakdown filter with one input and 4 outputs. Each output going to the appropriate channel.
  11. #20
    110
    I'm not really following. Could you point me to the help area that covers this? These arent Pixels or color controlled elements. I set the color there for the simulator.
