Results 1 to 10 of 10
Thread: Adding pixel sticks to an AC Renard show
    Dec 2015
    Saint Louis
    168
    Default Adding pixel sticks to an AC Renard show
    Hi everyone,
    Last year I ran an all AC Renard show. This year, Iím adding some pixels in, and I am using pixel sticks as my controllers. I am wondering what the easiest way is to add the pixel sticks to the show?
    Last year, I ran my show on a Raspberry Pi with FPP going out of the ethernet port to an RS-485 adapter to my Renard controllers which were daisy chained.
    Here is my question:
    Can I go out of the ethernet jack on the raspberry pi into a wireless router, then go out of the router to the RS Ė 485 adapter and then on to the Renardís?
    Then can the pixel sticks also connect to the wireless access point on the router?
    Well everything play nicely that way?
    If not, whatís the best way to set all this up?
    Thanks!
    Ken
    2016 - Static Light Show
    2017 - 72 Renard Channels - Roughly 4,200 Lights - 3 Sequenced Songs
    2018 - Added Pixels to Rooflines
    Website: www.doyonlights.com
    You Tube: https://www.youtube.com/channel/UCQ8...yLJieEEwDto7xg
    Adding Pixel Arches, Snowflakes, and Singing Bulbs in 2019!
    3,523
    Default Re: Adding pixel sticks to an AC Renard show
    I have not heard of an Ethernet to RS485 adapter. Are you sure you are not using an E1.31 bridge?
    Most APs have a switch built in. Mine has a four port switch an an upload port.
    At any rate:
    FPP Ethernet to a Switch.
    E1.31 bridge to the switch.
    AP to the switch (if they are not the same device).
    ESP associates to the AP
    FPP sends multicast E1.31 that is used by the ESP to output data.
    Dec 2015
    Saint Louis
    168
    My mistake.
    Actually, last year I ran the Rernard controllers from the Raspberry Pi using a USB to RS-485 adapter.
    Can I continue to do that this year, but also run an ethernet cable from the Raspberry Pi to a router, which would then send signal to the ESPixel sticks?
    Thanks!
    Ken
    UK S80 postcode
    1,386
    Hi, just for reference (A new thread can be started if there is interest):
    It can be done for about $10 with an Arduino Nano V3.0, ENC28J60 Ethernet shield and a RS485 breakout board, with a choice of output – DMX or Renard. Link.
    Columbus, OH
    4,220
    Yes, please do post these details!
    thanks.
    It can be done for about $10 with an Arduino Nano V3.0, ENC28J60 Ethernet shield and a RS485 breakout board, with a choice of output Ė DMX or Renard. Link.
    303
    Quote Originally Posted by kdoyon View Post
    My mistake.
    In this case, yes you can do it with only the addition of a Wifi Access Point. Renard will still go out via USB and your Pi will connect to the AP via TCP/IP. At the AP, your Pi will be on the same network as your pixel sticks.
    Folsom, CA, USA
    1,826
    Hi everyone,
    Thanks!
    Ken
    What Renard controllers do you have.....if they are Renard Plus controllers, there is a snap-in device for ESP controlled.....and Last year there was a thread on folks adding ESP Control to their Renard controllers. Barnabybear weren't you one of those helping folks on this process, or was that Ruppro.
    In Lights Therapy
    Jan 2010
    Mims, Fl
    662
    this is pretty similar to my question here - http://doityourselfchristmas.com/for...d-RenSS-boards
    I'm tagging along to see what else shows up. I need to catch up and get the pi running.
    Folsom, CA, USA
    1,826
    In Lights Therapy
    3,523
    My mistake.
    Thanks!
    Ken
    yes. i do it all the time. a pi has a usb adapter to drive my ren64 and uses ethernet to drive an f16
