Thread: General question regarding running video with Falcon Player
    17
    Default General question regarding running video with Falcon Player
    I've been running my light show for about three years now, using Vixen 3.3u2(#305) running on a dedicated Windows machine going out to a series of Alphapix, LOR and DMX lighting controllers. It's one show that uses about 8 sequences in a string that runs about 12 minutes in length.
    This year, I'm planning to add a video projector, which I'd like to tie into the Vixen light show. From what I've seen here, this is more than possible using a RaspberryPi running Falcon Player connected through E1.31. I don't need a strict time code type of communication. Just start/stop and preferably a sequence ID for playing the right video at the right time.
    What I'm trying to figure out is in the setup for Vixen, what do I use as the element for the RaspberryPi (assuming that it will be patched to a Streaming ACN E1.31 controller), and is there a way to have vixen send out a sequence number that will correspond to a particular video file on the Pi?
    If I could get the links to threads that would be helpful, that would be greatly appreciated!
    7,604
    Default Re: General question regarding running video with Falcon Player
    Take a look at this thread: https://diychristmas.org/vb1/showthr...ght=fancy+tune
    I explain the process in post #17
    17
    Thanks, John! I found a lot of helpful information on setting up the Pi over on the Falcon Player forum. I'm still waiting for some parts to arrive, but I can't wait to dive into this!
